900W H-class PA Amp with Limiter
Old 5th May 2010, 10:14 AM   #521
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by electra_ina View Post
Thanks alot Apex...Yes I undestood..If each trafo 10 Ampere, what 2 trafo will be 20 Ampere or 84vac x 20 A = 1680 watt??
Pozdrav..
No 2 trafo will be 10A, but 168vac and you have 1680watt.
Old 5th May 2010, 10:19 AM   #522
electra_ina is offline electra_ina  Indonesia
electra_ina's Avatar
Hvala unapred...
One againt..thanks so much...I understood...
Next..I will try B500 plus step up driver TL072 to H900...
I'm sorry.. too much "stupit" questions...
Regards..
Old 5th May 2010, 10:23 AM   #523
apexaudio's Avatar
Hvala unapred...
Regards..
Nema problema,
There is no stupit question
Old 5th May 2010, 10:26 AM   #524
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
hi apexaudio
greetings is it worthwile to put 4 more pairs will power increase
in 4 ohms for 1200 watt in 4 ohms what do we do
thanking you
andrew lebon
Old 5th May 2010, 11:06 AM   #525
apexaudio's Avatar
Originally Posted by andrewlebon View Post
hi apexaudio
thanking you
andrew lebon
I suggest to build complete amplifier, and use for a time. Adding 4 pairs will increase safty.
Old 8th May 2010, 05:49 PM   #526
khalsa is offline khalsa  India
Send a message via Yahoo to khalsa
Talking Hi Apex
Hi apex.
H900 watt project is very good. It really works very well and as well as output is very Punchy and clear.
I am confused in one thing, may be this is a problem that u might know.
I need the step driver test up procedure.
when we turn the amp on then the voltages on fuses are 55 +ve and -ve.
When we increase the volume voltage quickly goes upto 110 +ve and -ve on the fuses.
When we descrease the volume the voltage aren't goes down it remains the same on high voltages as 110 +ve and -ve on both sides. when we switch it off and turn it on again then voltages remain stable such as 55 +ve and -ve. but i think that the voltages should be vary with the volume controll. Plz help me.
I look forward to see ur reply
Khalsa
Old 8th May 2010, 06:00 PM   #527
apexaudio's Avatar
Originally Posted by khalsa View Post
Hi apex.
Khalsa
Voltage on the fuses is 55V, and if you measure with DMM, voltage in DC range can't be over 70V with high volume level, becouse step on 110V is fast and short, and you never can measure 110V on fuse. Something is wrong on your amp, can you post some pictures, maybe I can see mistake.
Old 9th May 2010, 08:07 AM   #528
Default hi apex
Hi apex I attach the photos
plz have a look.
Old 9th May 2010, 10:35 AM   #529
apexaudio's Avatar
plz have a look.
Component layout is ok, what is the fet useing in step driver? Try IRFZ44 for test. Where you connect input gnd from psu? Is output signal clear, without HF oscilation?
Old 9th May 2010, 11:52 AM   #530
Hi apex i am using ssh70n10a mosfet it contans 70 ampere 100volt.
Blue wire in input ground. i connect direct to the PCB.
Output is clear no problem.
plz chk this out.
Khalsa
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 09:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright ©1999-2017 diyAudio
