900W H-class PA Amp with Limiter
Old 3rd May 2010, 01:44 PM   #501
event horizon is offline event horizon  England
event horizon's Avatar
Originally Posted by eesbiboi View Post
does that mean, adding more output trannies would increase h900's power output up to such 1200w???... ...
No, not into the same loads - you'll need to increase the rail voltages to increase the power.
Running lower impedance loads (not recommended) you would have increased power output.
"Never let your morals prevent you from doing what is right!" Salvor Hardin
Old 3rd May 2010, 01:53 PM   #502
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
I agree with expirience diyer, I have 2500W amp, but this amp is not for first diy,
Old 3rd May 2010, 02:00 PM   #503
engel dela pena is offline engel dela pena  Philippines
Originally Posted by apexaudio View Post
I will post schematic for PSU and protect soon.
Full power of this amplifier is not 900W. Power with THD 0,5% is 1200W on 4R load, and 1800W on 2R load. Output transistor must be MJL4281A/MJL4302A for maximum power. For step mosfet use IRF2807. MJL21193/MJL21194 can be used for full power on 4R load.
Transformer minimum 1500VA for one channel 4X40V AC + 2X20V for protection circuit. 2X35A bridge and 8X10000uF/63V for PSU... are you still interesting to build this amplifier?
mjl4281a are 350v 230w 15a
mjl21193 250v 200w 16a
how about mj15003 250w 140v 20a
and mj15024 250v 250w 16a
Old 3rd May 2010, 02:06 PM   #504
apexaudio's Avatar
MJ15024/MJ15025 can be used (crown), MJL21193/MJL21194 also.
MJ15003/MJ15004 can be used only for B500 (B250) with +/-65VDC rail voltage.
Old 3rd May 2010, 02:13 PM   #505
mjl4281a are hard to find locally
but mj15025 are already available maybe i'll go for mj15025 next time
250w 250v
what is psu specs for mj15025
transformer ,caps, diode
Old 3rd May 2010, 02:17 PM   #506
apexaudio's Avatar
250w 250v
No need for MJL4281A, I use it only with higer rail voltage for increase power on 8R load,
Old 3rd May 2010, 02:31 PM   #507
many people making money of assemblying then selling like what you called "monster amp" thats not new here in our place,i'm saying this because i'm one of their victim
they build me monster amp and i pay them,i still remember as they say i will build you a thousand watts amp,he he he.that's the reason why i dig to much of this knowledge and because i'm a victim of people who take advantage to those who knew very little in this field.i'm verry thankful to all the people specially APEX for sharing their knowledge and experience in this field,and support
warm'st regards
Old 3rd May 2010, 07:44 PM   #508
apexaudio's Avatar
warm'st regards
Not this "monsters" I mean schematics on the net, but expirience is not for free,
Old 3rd May 2010, 10:42 PM   #509
for clarification
i did not mean your design,
and experience,i can thank them for they fool me once,but because of them i gained experience building my owned stuff,with the help of the community
regards
Old 4th May 2010, 08:38 AM   #510
apexaudio's Avatar
for clarification
regards
It's clear, I mean "monsters" from your post,
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 09:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright ©1999-2017 diyAudio
