900W H-class PA Amp with Limiter
Old 6th March 2010, 03:04 PM   #21
audiomachines is offline audiomachines  Philippines
Send a message via Yahoo to audiomachines
thanks for sharing
Old 6th March 2010, 03:20 PM   #22
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
hi apex
greetings
1 any substitute for diode BAV 21
2 any substitute for diode SAF 1603 very hard to find
can you show inputstage schematic and power supply schematic
waiting to make your amplifier thanking you
Old 6th March 2010, 04:51 PM   #23
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by andrewlebon View Post
hi apex
greetings
1 any substitute for diode bav 21
2 any substitute for diode saf 1603 very hard to find
bav21 > byd73c, byd33d
sfa1603 > byv79/200, byw29/200
Old 7th March 2010, 10:14 AM   #24
apexaudio's Avatar
Landscape view on H900
Old 7th March 2010, 03:02 PM   #25
powerflux is offline powerflux  Netherlands
thank you, i'd most interrested in the 'vas' stage.
the railswitching is nice too
Old 7th March 2010, 10:04 PM   #26
apexaudio's Avatar
I work on my website EUnet Hosting
Most information about my work will be there. I will have more time for reply when site was finished.
Regards Mile
Old 8th March 2010, 01:09 AM   #27
hi apexaudio
greetings can you share power supply schematic
1 transformer used with filter capcitors
2 current capcity amperes for full output 900 watts
collecting parts for amplifier
thanking you
andrew lebon
Old 8th March 2010, 06:05 PM   #28
apexaudio's Avatar
hi apexaudio
thanking you
andrew lebon
I will post schematic for PSU and protect soon.
Full power of this amplifier is not 900W. Power with THD 0,5% is 1200W on 4R load, and 1800W on 2R load. Output transistor must be MJL4281A/MJL4302A for maximum power. For step mosfet use IRF2807. MJL21193/MJL21194 can be used for full power on 4R load.
Transformer minimum 1500VA for one channel 4X40V AC + 2X20V for protection circuit. 2X35A bridge and 8X10000uF/63V for PSU... are you still interesting to build this amplifier?
Old 8th March 2010, 07:07 PM   #29
event horizon is offline event horizon  England
event horizon's Avatar
Hi Mile
Thanks for sharing the class H circuit, having looked at it & it's simplicity i think i'll be incorporating it into a few amps that i'll be building in the future
You have just saved me the hassle of building a switchmode PSU even though i didn't realise it at the time when i saw your circuit. Instead i can use transformers i already have but build a high power high frequency charge pump circuit to power the high voltage rails
Cheers for making me think, & for saving me time, hassle & money
Bests, Mark
"Never let your morals prevent you from doing what is right!" Salvor Hardin
Old 8th March 2010, 07:26 PM   #30
qsa is offline qsa  Germany
qsa's Avatar
Class H DIY good idea,...
check RMX 5050 schematic for DIY ideas...
I want spend my time to add Class H in Quasi NMOS Amp too and share experience with another DIY people,...actually i dont have much time for DIY
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 10:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 03:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 07:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 05:30 AM
