900W H-class PA Amp with Limiter
Old 20th January 2014, 06:41 AM   #2761
waylene is offline waylene  South Africa
I only get power on my positive rail, this is only the positive rail that warm up when I pump up some volume. The negative rail stay cold and don't warm up like the positive rail. Is there any ting you can think of what can be the problem on it?
Old 20th January 2014, 07:04 AM   #2762
Old 20th January 2014, 08:56 AM   #2763
disconnect the Amp from the PSU.
Check the PSU thoroughly.
regards Andrew T.
Old 20th January 2014, 09:52 AM   #2764
Hi AndrewT I all ready to that two times, there is power on the amp. When I take of fuse on Negative rail, amp is still playing on with out the fuse.
Old 20th January 2014, 10:05 AM   #2765
You see here, I use one trapo here that give out +70 +45 0V -70 -45 volt dc out. I use this trapo for only testing the amp.
Old 20th January 2014, 10:12 AM   #2766
you have checked the PSU.
You have connected the amplifier.
the amplifier does not work.
Then either the connections are wrong, or the amplifier is wrong.
regards Andrew T.
Old 20th January 2014, 10:17 AM   #2767
You see here sir? Where I mark with green, this positive rail warm up when I pump up some volume, but the negative rail where I mark with red, never switch on, transistor stay cold and never warm up.
Old 20th January 2014, 10:40 AM   #2768
sandman15th is offline sandman15th  Philippines
sandman15th's Avatar
Please check or How much voltage that u get on the fuses? It must the same voltage,then when u put high volume the voltage must increase..
Old 20th January 2014, 06:29 PM   #2769
gantex is offline gantex  Indonesia
gantex's Avatar
im not see any wrong here, or i cannot see? First clean the bottom cooper then Try to replace IR2117 on + rail with IR2117 on - rail, just to check if this both IC is OK. I hope this work.
Regard.
" Look at the sky.. GOD smiles for you "
Old 21st January 2014, 07:10 AM   #2770
JOHN BALI is offline JOHN BALI  Indonesia
JOHN BALI's Avatar
Hi, Waylene,
this is good suggestion
Regard.
Clean the bottom, then try to put other IR2117 from working amp... Maybe the IR2117 not doing the job, I have someone here warning about IR2117.
He have bad IR2117 that can oscillate by itself...
If changing them don't solve the problem, maybe you have broken trace or broken transistor, check 2N5401-2N5551 MJE340-350
or you can try to measure the voltage on each base to ground... If you find different more than 10%(positive & negative side) then you will start to find where is your problem
Thank you, I wish you happy
peace & G B U
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 09:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright ©1999-2017 diyAudio
