900W H-class PA Amp with Limiter
Old 17th January 2013, 12:46 AM   #2431
wattaniya is offline wattaniya
Originally Posted by ravpreet420 View Post
firstly add 1k pre set and set voltage according to need .first time set pre set in center and rotate slowly .....after set voltage on base . remove the pre set carefully and check the pre set on multimeter according the dmm reading you add resister on place of pre set....
thanks for the reply ravpeet, i will try.
Old 17th January 2013, 08:45 AM   #2432
clovi_kate is offline clovi_kate  Philippines
Send a message via AIM to clovi_kate Send a message via MSN to clovi_kate Send a message via Yahoo to clovi_kate
for soerdjanto and Rohmad fauzi, may i know what type of metal you used for toroid core traffo?..i'm planning to build a transformer but i dont know which type of metal is good for 220v/60Hz line.
Old 17th January 2013, 09:06 AM   #2433
Rohmad fauzi is offline Rohmad fauzi  Indonesia
CRGO sir..
Old 17th January 2013, 09:23 AM   #2434
is that a silicon steel?..does it have common name?..i'll try to find it here,tnx sir..
Old 17th January 2013, 01:32 PM   #2435
rizqi is offline rizqi  Indonesia
rizqi's Avatar
Send a message via Yahoo to rizqi 900W H-class PA Amp with Limiter
Default DETEX 2500
Originally Posted by andrewlebon View Post
TD CLASS MAYBE SOMEONE TRY IT
warm regards
andrew lebon
nice designs,..
where the schema for that,?..
thanks n regards
Better try it ...
Old 17th January 2013, 04:07 PM   #2436
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
detex never gives any schematic
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 17th January 2013, 11:12 PM   #2437
rizqi's Avatar
warm regards
andrew lebon
whether dertex tested well at TD class?
Better try it ...
Old 5th February 2013, 07:26 PM   #2438
sergiu_oct is offline sergiu_oct  Romania
hi apex sir,
for this project may use an alternative voltage transformer which has 2 x 0 - 45 - 68Vac?
Old 5th February 2013, 08:51 PM   #2439
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by sergiu_oct View Post
hi apex sir,
Yes 2 x 0 - 45 - 68vac is ok.
Old 8th February 2013, 01:50 AM   #2440
nugroho is offline nugroho  Indonesia
hi miles,
can i use this modification of using 2 transformer but diferent size?
like this:
regard
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 10:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 03:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 07:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 05:30 AM
Copyright ©1999-2017 diyAudio
