900W H-class PA Amp with Limiter
Old 15th December 2012, 05:06 AM   #2371
ChingTan is offline ChingTan  Philippines
ChingTan's Avatar
Send a message via Yahoo to ChingTan
i like this powerful amp thanks.. mile..
Old 15th December 2012, 06:19 AM   #2372
rizqi is offline rizqi  Indonesia
rizqi's Avatar
Send a message via Yahoo to rizqi 900W H-class PA Amp with Limiter
[QUOTE=wiljj78;3265171]Hello Rizqi,
Thanks.. This design have not been tested yet i'm still trying to find some error before i etch, but you can also review and let me know if you found any mistake so i can correct the error.
Send me your email add so i can forward you the sprint layout file.
Your layout is correct but adjust as the distance between the10uF160v 10uf63v...still less loose... nice
Better try it ...
Old 15th December 2012, 07:39 AM   #2373
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
It looks very very nice! How much power have you acchived and how good do those heatsinks cool it down? I am asking because i am trying to build one 500W amp so i need some guidance,clue how big the heatsink should be for that power.
Old 15th December 2012, 08:24 AM   #2374
ChingTan's Avatar
this heat sink i use is a bit small that's why i use two fan to cool it down.
Old 15th December 2012, 09:07 AM   #2375
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Nice work,
Old 16th December 2012, 07:53 AM   #2376
rizqi's Avatar
Hi mr. Mile .... I have built 2 units of Apex H900
and now I am building a 3rd H900 apex with two transformer-30 Amphere 55vac-47vac-0-47vac-55vac. and 4x10000uf 75V (Sprague).
My question is: can use 95vac-47vac-0-47vac-95vac?
output transistor using original MJLJL3281A (NPN) MJL1302A (PNP) ...
thanks and regards.
Better try it ...
Old 20th December 2012, 02:37 AM   #2377
nugroho is offline nugroho  Indonesia
still in progress:
Old 21st December 2012, 12:25 PM   #2378
rizqi's Avatar
Thumbs up H900
3rd H900 - my Project
30A transformator 80vac- 40vac-0-40vac-80vac
output transistor using original MJL3281A (NPN) MJL1302A (PNP)
Better try it ...
Old 21st December 2012, 01:18 PM   #2379
apexaudio's Avatar
Nice work, I sugest to rotate modules 180deg (heatsinks near transformers.
Old 21st December 2012, 04:34 PM   #2380
44250's Avatar
That is good suggestion-even the tunnel would be better formed so more air would go through heatsink(s)!
It looks great are those 10 000uF or 100 000uF capacitors?
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 10:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 03:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 07:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 05:30 AM
Copyright ©1999-2017 diyAudio
