900W H-class PA Amp with Limiter 900W H-class PA Amp with Limiter - Page 232 - diyAudio
Old 16th November 2012, 01:13 AM   #2311
iiee3602 is offline iiee3602  Philippines
Originally Posted by DAMANHURI View Post
I have yet to install the fan into the relay module test only can work or not, after I check the IC 7912 and R 5 Watt hot, with no load (Fan)
Check your layout. there is missing link on 1N4148 to supply +24
Old 16th November 2012, 03:06 AM   #2312
Please see attach picture!
Old 17th November 2012, 07:18 AM   #2313
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Post #2305 shown it's been rectified.... now he has heat issue with 47R/5W and IC 7912.
Damanhuri, My protect it only get warm this two component having the fan connected, if the fan is disconnected they must be cold.
Old 17th November 2012, 12:34 PM   #2314
DAMANHURI is offline DAMANHURI  Indonesia
DAMANHURI's Avatar
I'll try to replace the 7912 IC tomorrow
Best regards - Damanhuri
Old 17th November 2012, 03:33 PM   #2315
princenk007 is offline princenk007  India
princenk007's Avatar
Hello Mile sir,
Having built B500 I m impressed by the performance of the amp. The next step is to get the most juice out of my 2.5kva toroid and 2kw speakers.. I have gone through this thread and finally decided to built H900. What I couldn't find is H900 schematic with 8pairs of output transistors to support 2ohms and 16 ohm loads. Maybe I have missed it. So I am looking for H900 triple emitter follower schematic/circuit . I request Mile sir or diy members to please help me with H900 tef circuit. Thank you :-)
Old 18th November 2012, 02:03 AM   #2316
rizqi is offline rizqi  Indonesia
rizqi's Avatar
Send a message via Yahoo to rizqi 900W H-class PA Amp with Limiter
Hi mr. Damanhuri.... have u finish make protect?... share that for diy...
nice project
Better try it ...
Old 18th November 2012, 02:08 AM   #2317
rizqi's Avatar
Thumbs up H900 truelly diyers
Happy holliday to all...
This forum is verry helpfull. Specially thanks to mr mille...
Your dsign is unic n naturally but expert....
good job sir...
Nice..
Better try it ...
Old 19th November 2012, 12:38 AM   #2318
DAMANHURI's Avatar
nice project
there are constraints on the regulator Fan. I would replace the 7912 IC
Old 19th November 2012, 04:27 AM   #2319
Thanks for reply. Damanhuri, pls check the reisistance of your IC7912 and 47R/5W.
Old 20th November 2012, 04:33 PM   #2320
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
good job sir...
Nice..
Thanks,
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 09:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright ©1999-2017 diyAudio
