900W H-class PA Amp with Limiter
Old 26th September 2012, 07:36 PM   #2251
wattaniya is offline wattaniya
Originally Posted by 44250 View Post
Would you two post the bottom layout,pcb for me? I have this scheme but i donīt have any other files...
HERE IT IS.
Old 26th September 2012, 08:45 PM   #2252
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
Thumbs up GREAT! :)
Originally Posted by nazirdigi View Post
HERE IT IS.
Thank You!
Old 27th September 2012, 07:00 AM   #2253
sandeep kayarkar is offline sandeep kayarkar  India
Default HAPPY BIRTHDAY
MANY MANY HAPPY RETURNS OF THE DAY SIR MILE
Old 27th September 2012, 11:56 AM   #2254
happy birthday apex sir.
Old 27th September 2012, 12:17 PM   #2255
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Default Happy Birthday!!!
Mr. Mile,
Wishing you all the best and more success....
Happy Birthday!!!!
Old 27th September 2012, 12:36 PM   #2256
Tube Pro is offline Tube Pro  Macao
Tube Pro's Avatar
Happy Birthday Mile. More power.
Old 27th September 2012, 04:51 PM   #2257
khalsa is offline khalsa  India
Send a message via Yahoo to khalsa
Happy birthday sir Mile
Old 27th September 2012, 09:24 PM   #2258
crazymechanic is offline crazymechanic  Latvia
Default h900
Hi , also from me a happy birthday.
My problem is i had much work to do so only now I am back to my project , could someone please tell me what could be the problem when testing the amp with sine waves and watching the output at little input level everything works ok. No distortion no problems, the outcoming signal looks without distortion and so but when turning the input level up to say about 0.6 or higher volts the output transistors stage opens fully up and the transistors are blown but not the fuse which is like originally asked 15A.
I have my ideas what could be wrong maybe you could give me yours?
Thanks.
Old 28th September 2012, 02:36 AM   #2259
iiee3602 is offline iiee3602  Philippines
Hi, sir mile belated Happy Birthday
Old 28th September 2012, 10:27 AM   #2260
Originally Posted by crazymechanic View Post
................when testing the amp with sine waves and watching the output at little input level everything works ok.................. the outcoming signal looks without distortion and so but when turning the input level up to say about 0.6 or higher volts the output transistors stage opens fully up and the transistors are blown but not the fuse which is like originally asked 15A............
Are you using an oscilloscope to "look" at the output?
How long do you "test" at the higher output levels?
How hot do the output devices get?
Maybe the 15A fuse is too big.
900W into 4r0 is equivalent to 60Vac and 15Aac. The supply rails should be fused at about 7A or 8A. The output rail to the speaker could be fused at 15A.
But those fuses will take seconds to blow, if you overload the amplifier. During those few seconds the output stage and the drivers will have blown. Semiconductors fail a lot faster than fuses !!!!!!!!
regards Andrew T.
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 10:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 03:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 07:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 05:30 AM
Copyright ©1999-2017 diyAudio
