900W H-class PA Amp with Limiter
Old 13th February 2012, 09:52 AM   #1941
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay 900W H-class PA Amp with Limiter
black step driver of m10 / k10 is base on h900 of apex
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 13th February 2012, 02:17 PM   #1942
remle114 is offline remle114  Philippines
Default H900 with discrete step driver step
Old 13th February 2012, 04:21 PM   #1943
QQ12e5k1 is offline QQ12e5k1
Default Vertex
Hey Irvynejay,does your vertex working good??
I saw you have wrong direction on tr bc series on diff stage....
Old 13th February 2012, 10:33 PM   #1944
irvynejay's Avatar
OT<
vertex are fine until now still waiting to be pack hehehe
Old 13th February 2012, 11:34 PM   #1945
OT<
Ow...good job...
But I mean the first pcb you upload that use orange elco...
Old 13th February 2012, 11:43 PM   #1946
irvynejay's Avatar
ah ok i was using different king of transistor at that time that's why it is on opposite direction
2n3906 /04
Old 15th February 2012, 12:35 AM   #1947
iiee3602 is offline iiee3602  Philippines
Sir apex, it is ok to replace optoresistor NSL32 with optotransistor? If ok , please show me the schematic.
Old 17th February 2012, 01:40 PM   #1948
mackomester is offline mackomester  Ireland
Hi all DIYers!
I have the B500 built, it's just about to test. I also plan to build the H900.
A few question about this two amps:
-I have some VTL5C1 lying around, can it be used in the limiter with 47k parallel on resistor side?
-I also have a bunch of MJW21195-MJW21196 pairs, would be they ok instead of 5200-1943?
And one more thing, I want to use the H900 for bass guitar on 4 ohm load. It would be safe enough on low frequencies?
Thanks for any advice, keep up the nice work!
Old 17th February 2012, 04:15 PM   #1949
effebi is offline effebi  Italy
effebi's Avatar
Originally Posted by mackomester View Post
Hi all DIYers!
I belive your Motorolas (ONSEMI) are much BETTER than the 5200/1943 , especially in a PA / Heavy Duty application.
Have a look on SOA curves....
Old 17th February 2012, 04:58 PM   #1950
Thats good to hear, I didn't actually check the datasheet.
I have 14 pairs of MJW's, my goal is 1500W on 4 ohms.
Would be that possible with one channel of H900? Or easier
with a bridged B500? I don't want to bridge if not necessary...
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 09:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright ©1999-2017 diyAudio
