900W H-class PA Amp with Limiter
Old 30th July 2011, 12:39 PM   #1491
wattaniya is offline wattaniya
Originally Posted by mkubawat View Post
Tell me, soft start circuit used or not
hi mkubawat.
i am not using soft start.
now i think ok for the 5sec delay. the relay is connecting after 5sec.
but when i off the amp with low volume, big sound is coming like (top) .
Old 30th July 2011, 02:43 PM   #1492
mkubawat is offline mkubawat  India
Originally Posted by nazirdigi View Post
hi mkubawat.
There are two reason in my mind for this type of problem
1. if sound comes immediate with turn of then it is due to loose contacts in AC side wiring or main switch contacts
2. if after 2-3 sec delay then check amp's pre IC supply please try to stabilize it.
tell me if not solved
Old 30th July 2011, 05:31 PM   #1493
thanks mkubawat.
i checked on off main switch.
problem is on off switch.
now no on off thumbs. no sounds on off.
thank u very very much for your cooperation.
Old 30th July 2011, 06:46 PM   #1494
STAGE4 is offline STAGE4  Sri Lanka
STAGE4's Avatar
Old 30th July 2011, 07:09 PM   #1495
STAGE4's Avatar
use mjl21193,mjl21194 for the outputs and drivers & you can use two types of relays for the speaker protection relay,(12V)..good sound...enjoy it..
Old 30th July 2011, 07:31 PM   #1496
hello cheshtap.
where can i buy mjl21194 numbers in sri lanka , i mean shop address.
thanks.
Old 31st July 2011, 05:59 AM   #1497
Dear CHESTAP
Your work is appreciable , but where are schematic & supply detail.
Old 31st July 2011, 06:18 AM   #1498
engel dela pena is offline engel dela pena  Philippines
Old 31st July 2011, 07:04 AM   #1499
this schematic does not match
Old 31st July 2011, 07:23 AM   #1500
eesbiboi is offline eesbiboi  Philippines
eesbiboi's Avatar
Originally Posted by Tekko View Post
eesbiboi, those are 5 volt zener diodes and part of the railswitching circuit.
thank you dear tekko...
now im wondering which schema to follow...
i got this other one from a different forum posted also by sir chestap
seems to have a bit of insimilarity
regards
ees...
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 10:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 03:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 07:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 05:30 AM
