900W H-class PA Amp with Limiter
Old 23rd March 2010, 11:21 PM   #121
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Default Apex h750
Here is PCB for APEX H750.
Old 24th March 2010, 12:35 AM   #122
engel dela pena is offline engel dela pena  Philippines
Default apex h 750
apex
how can we make a balanced input for h-750
do you have a circuit
or modification
Old 24th March 2010, 12:50 AM   #123
apex
can i use D5LC20
this is 3 pin dual diode ultra fast
16 a 200v prv
Old 24th March 2010, 01:19 AM   #124
apexaudio's Avatar
Default XLR input
Circuit for XLR (balanced) input, and level control.
Old 24th March 2010, 01:23 AM   #125
apexaudio's Avatar
Originally Posted by engel dela pena View Post
apex
can i use D5LC20
16 a 200v prv
U can use this diode on H900 V2 PCB.
Old 24th March 2010, 01:28 AM   #126
apex
thanks
how about psu schematic
Old 24th March 2010, 01:32 AM   #127
apexaudio's Avatar
See post #67 for PSU.
Old 24th March 2010, 01:44 AM   #128
Default psu
apex
5 terminal must be from transformer the center must be ov,terminal 1,2,4,5 must be the x-former 4x40v
the other four terminal must be dc with discharge resistor,which is for +/-6o?and +/-120?
Old 24th March 2010, 01:48 AM   #129
apexaudio's Avatar
apex
Yes, I will post schematics soon.
Old 24th March 2010, 01:57 AM   #130
Default class h power supply
http://www.crownaudio.com/pdf/amps/grbgpapr.pdf
crown amp patented the class g
and qsc the class h
do they have the same psu?
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 10:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 03:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 07:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 05:30 AM
Copyright ©1999-2017 diyAudio
