900W H-class PA Amp with Limiter
Old 18th December 2010, 02:15 PM   #1031
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
PCB for PA Stereo Protect, but I not suggest use this protect with B500 and H900. This protect use for 50-250W amps.
Old 18th December 2010, 02:37 PM   #1032
aman khalsa is offline aman khalsa  India
aman khalsa's Avatar
hello sir
today i test my h900..it work,s ...
but it clips when output is 35v..i use 110-55-0-55-110V DC...
how can i know HV is working......???
thank u sir
Old 18th December 2010, 02:51 PM   #1033
apexaudio's Avatar
Originally Posted by aman khalsa View Post
hello sir
thank u sir
35V AC, DC, RMS, peak...
Old 18th December 2010, 03:30 PM   #1034
amp clips when output voltages is 35 AC .. . peak output is 50V AC Without limter....
Old 18th December 2010, 03:59 PM   #1035
apexaudio's Avatar
Do you see clip on the scope? Describe your measurement...
Old 18th December 2010, 04:01 PM   #1036
i have no scope sir i have only DMM....
Old 18th December 2010, 04:35 PM   #1037
NMOS is offline NMOS  Germany
NMOS's Avatar
Originally Posted by apexaudio View Post
Use this circuit for stereo, only add DC protect for channel 2. If you have two heatsinks add BD241C(TIP31C) in parallel.
Hello APEX
have add in your PA PROTECT design
1. LED WARNING ! HEATSINK TEMP 75deg !
and
2. 35deg FAN ON / OFF (dont like noisy FAN if using amp with low output power or HI-FI)
could this work ?
Old 18th December 2010, 04:45 PM   #1038
NMOS's Avatar
can you share with us protect schematic for H900 and B500
Old 18th December 2010, 06:00 PM   #1039
apexaudio's Avatar
Multi meter can read only DC or 50Hz RMS AC voltage. If you use LED instead NSL32, and run amp with 0,+/-55v,+/-110v rail voltage, LED will light on if you have 95v peak voltage on amp out with high level audio input. With low rail voltage of +/-55v, amp will clip at about 50v output voltage, and LED can't light on if step driver not work and not increase rail to +/-110v at peaks.
Old 18th December 2010, 06:05 PM   #1040
apexaudio's Avatar
Originally Posted by NMOS View Post
Hello APEX
and
could this work ?
Your circuit for 35deg fan on/off is wrong. Use PNP transistors to switch fan (+) to GND. PA protect is for B500 and H900, I just suggest not use stereo PA protect for this powerfull amps.
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 10:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 03:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 07:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 05:30 AM
