900W H-class PA Amp with Limiter
Old 3rd December 2010, 04:11 AM   #1001
gooseneck is offline gooseneck  Philippines
To Sir Mile,
i have a diagram here by pagarigan i used it as my power amp since year 1992 and it work so nicely without any problems, supply is 70V-0-70V, and i want to employ TL072 stepdriver to make it a Class H power amplifier. please help me to do this...thanks and merry christmas....
Old 3rd December 2010, 03:45 PM   #1002
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by gooseneck View Post
To Sir Mile,
Output stage on your amp is similar to crown, use crown schematic, TL072 classH step driver is also based on crown.
http://www.crownaudio.com/pdf/legacy/s-c1100as-03.pdf
Old 9th December 2010, 01:33 PM   #1003
apexaudio's Avatar
Default APEX B181
18 inch horn-reflex sub.
Old 14th December 2010, 06:59 PM   #1004
apexaudio's Avatar
Dual 18 inch Horn-Reflex Sub
Old 14th December 2010, 10:21 PM   #1005
apexaudio's Avatar
B181
Old 14th December 2010, 10:52 PM   #1006
apexaudio's Avatar
H900 and B500 have inverted output phase for useing with B2181 and B181 subs. Speakers in B2181 and B181 are in reverted position for beter cooling.
If you use B2181 and B181 with another amps you must reverted (+) and (-) on speaker terminal or you can turn around speaker in standard position, also if you use H900 and B500 with another speakers you must reverted (+) and (-) on speakers terminals or amps output terminals.
Old 14th December 2010, 11:39 PM   #1007
apexaudio's Avatar
JBL profesional speakers have inverted phase, no need to invert phase if use with H900 and B500.
Old 15th December 2010, 05:18 AM   #1008
darwinbibit is offline darwinbibit  Philippines
Originally Posted by ravslanka View Post
hi apex,
this is the final pcb.what about zf15 connected to nsl32.iwill be using
mur1560/stth15r06 instead of 1620ct.will it be ok.
pcb size is 296x62mm .
http://img535.imageshack.us/img535/3548/46787365.gif
thanks in advance
ravs
be a vegeterian.....
ravslanka sir do you have a parts placement guide of your pcb foil pattern if you have can you post it pls. thanks
Old 16th December 2010, 08:27 AM   #1009
ravslanka is offline ravslanka  India
hi darwinbibit,
here is foil pattern and silk.do you gonna use toner transfer method.
pdf is mirrored.
best regards
ravs
be a vegeterian......
Old 16th December 2010, 08:40 AM   #1010
Tekko is offline Tekko
Banned
That layout will not work, the power devices on the left doesent have the common end on the emitter resistors tied to the right side emitter resistors where the speaker output is.
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 10:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 03:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 07:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 05:30 AM
