Old 2nd March 2010, 05:30 AM   #1
Rafael L's Avatar
Default No feedback amp
Hi
I like to know how to use this simple topology without negative feedback.
In other circuits use complementary pair in the input to avoid the DC output, for the simple circuit below, what is the simplest way to avoid the DC output, when negative feedback is removed?
Old 2nd March 2010, 05:53 AM   #2
How are you going to select the total gain if you eliminate the feedback?
Old 2nd March 2010, 06:29 AM   #3
alexcp is offline alexcp  United States
alexcp's Avatar
You can replace emitter degeneration resistors (R2 and R3) in the differential pair with a trimpot, connecting its wiper to the current source (Q3); this would allow you to adjust DC offset.
However, open loop gain will be high enough to make precise balancing difficult, and the result unstable. This amp without NFB is likely to be impractical, much as an op amp without NFB.
Old 2nd March 2010, 06:43 AM   #4
Rafael L's Avatar
Placing a voltage divider, generally difference between the bases of differential pair is 5mV-30mV, depends on the gain of the VAS.
DC I have is half the source (15V), I need another transistor to compensate, but I do not know how is the circuit!
Old 2nd March 2010, 06:43 AM   #5
Bonsai is offline Bonsai  Taiwan
Is this for simulation purposes? If yes, make R21 a very low value (.001 Ohms) and C4 a very high value. You can then run your AC sims to get an idea of th eopen loop response.
If you want to build a low or ZGFB amp, then you can try heavy degeneration of the input devices and/or loading VAS to reduce the loop gain. A third method is to tap off the feedback signal from th e VAS rather than th eoutput, but this leaves you with no feedback top correct the cross over distoprtion, unless of course you are planning to run it heavily class A. Of course, you can use any combination of th e above as well (e.g. heavy degen of th e LTP and take f/back off the VAS).
bonsai
http://www.hifisonix.com/
Old 2nd March 2010, 07:09 AM   #6
Rafael L's Avatar
[QUOTE=Bonsai;2103958]Is this for simulation purposes? If yes, make R21 a very low value (.001 Ohms) and C4 a very high value. You can then run your AC sims to get an idea of th eopen loop response.
Yes is for simulation, this will increase the gain and had to use two voltage dividers. It is used in opamps
I'm trying to do is one pre-amp in class A, +- 4V RMS. I want to remove the negative feedback because not is necessary!
Distortion in 20KHz (with feedback)
Harmonic Frequency Fourier Normalized Phase Normalized
Number [Hz] Component Component [degree] Phase [deg]
1 2.000e+04 5.500e+00 1.000e+00 -1.00° 0.00°
2 4.000e+04 8.877e-06 1.614e-06 -119.72° -118.73°
3 6.000e+04 1.169e-06 2.126e-07 -141.78° -140.79°
4 8.000e+04 1.533e-07 2.787e-08 176.90° 177.90°
5 1.000e+05 3.605e-08 6.555e-09 167.56° 168.55°
6 1.200e+05 3.098e-08 5.633e-09 -170.17° -169.18°
7 1.400e+05 1.221e-08 2.221e-09 -155.21° -154.21°
8 1.600e+05 2.014e-08 3.662e-09 166.43° 167.43°
9 1.800e+05 2.153e-08 3.916e-09 171.56° 172.56°
Total Harmonic Distortion: 0.000163%
Old 2nd March 2010, 08:35 AM   #7
revintage's Avatar
No wonder you have low distortion-figures as NFB might be somewhere in the +40db region.
It will be easier if you do a Diamond output stage with a servo. Crossover-distortion will not be a problem as long as you stay in Class-A. Check this out:
http://www.andiha.no/articles/audio/cascfig/sch01.gif
Cascode Power Amplifier
Brgds
Lars
Old 2nd March 2010, 09:09 AM   #8
Rafael L's Avatar
Negative feedback is 36 dB, so what the distortion in open-loop is <0,01%.
the circuit is the blameless without power TRs output.
With VAS balanced, I had already seen, here an example:
http://users.ece.gatech.edu/mleach/papers/tcir/tcir.pdf
But would like a solution to blameless.
Old 2nd March 2010, 10:04 AM   #9
wahab is offline wahab  Algeria
[QUOTE=Rafael L;2104068]
QUOTE]
I would call it a LIN...
Douglas Self didn t invent nothing in that matter, yet, a lot
of people name this topology with his "trade marks"..
Old 2nd March 2010, 10:49 AM   #10
AKSA is offline AKSA  Australia
The original 1955 Harry C Lin amp used singleton input, SE VAS and PNP germanium quasi output stage with Sziklai npn driver.
If you want to build the amp without feedback, then to be strictly correct you must eschew interstage feedback, so only local feedback is acceptable..... this is really quite difficult.
As Bonsai suggests, it is best done with lashes of emitter degen on the LTP, lots of degen on the VAS, and some pretty stiff loading or feedback on the VAS collector. If the output stage is not operating in Class A, crossover could be an issue with no global feedback.
Interstage feedback between VAS collector and the LTP - the same RRC network transposed from output back to the VAS collector, and thence to fb node - is a better suggestion, however, as it will also reduce source impedance driving the output stage, always a good thing.
I have done a suitable Class AB zero global fb amp in the attachment, with simulation. It uses lashes of local feedback, and then adds interstage feedback from VAS back to LTP. It is possible to cut OLG to about 30dB with even more local and no interstage, but the results are not as good. As you can see, H2 is around -48dB, not very impressive. However, if you build this circuit you will be quite surprised......
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Looking for Feedback on this No Feedback Amp. MJL21193 Solid State 82 6th July 2009 02:53 AM
SOHA Amp &amp; PSU Layout, need feedback trip-pcs Tubes / Valves 5 22nd August 2007 04:48 PM
Feedback on this Amp pgbhat Solid State 4 19th December 2006 08:05 AM
'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' mikeks Solid State 62 20th July 2005 08:03 AM
Page generated in 0.12514 seconds (82.97% PHP - 17.03% MySQL) with 11 queries
