Advice needed on RoHS regulations
Old 26th February 2010, 03:09 PM   #1
jez is offline jez  United Kingdom
Default Advice needed on RoHS regulations
I have heard a rumour from 3 different industry sources that if the total mass of a piece of electronic equipment is high (very heavy transformers, case work etc) then the percentage of the total mass due to lead in the solder may be small enough to allow the item to be RoHS compliant.... Can anyone confirm this? Trawling the internet has not been very productive on this subject other than to hint that it is probably not true. However, one of my sources is a well known hi-fi manufacturer who should know what he's talking about....and it wasn't April 1st when I heard it!
Old 26th February 2010, 03:58 PM   #2
Chris Jennings is offline Chris Jennings  United Kingdom
26. For the purposes of the RoHS Regulations, a maximum concentration value of up to 0.1% by weight in homogeneous materials for lead, mercury, hexavalent chromium, PBB and PBDE and of up to 0.01% by weight in homogenous materials for cadmium will be permitted in the manufacture of new EEE. These values were established through the adoption of a Commission Decision on 18 August 2005.10
27. “Homogeneous material” means a material that cannot be mechanically disjointed into different materials.
So solder has to be less than 0.1% lead
HTH Chris
Old 26th February 2010, 04:27 PM   #3
jcx is online now jcx  United States
I believe the looser "assembly/finished product" was the original formulation used to "sell" the regulations but the current interpretation/"mission creep" as used by the bureaucracy is that each individual component/sub assembly should meet the regs, and that their meaning of "reduction" is elimination of any intentional use of prohibited materials in consumer marketed products
I recall reading that a multimillion dollar development and retooling by a major semi manufacturer to go "lead free" on component leads saves single digit # of car battery amounts of lead yearly – seems like a bounty on abandoned/discarded car batteries, lead glass decorative “crystal” or replacement of a few tern-plate roofs would have been cheaper and better for the environment, or how about cleaning up 2 world wars worth of bullets buried in farmland and forest battle sites throughout Europe?
Old 26th February 2010, 09:58 PM   #4
Bigun is offline Bigun  Canada
Bigun's Avatar
Car tyres (tires) are even worse...
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 27th February 2010, 03:03 PM   #5
Thanks for the replies. That's kind of as I thought...
It does seem ridiculous that so little of the worlds annual lead usage is in electronic equipment and yet it has been banned!
Old 28th February 2010, 04:43 AM   #6
indianajo is offline indianajo  United States
indianajo's Avatar
Default only big boys can make toys
The amount of lead they were putting in CRT terminals to shield the X-rays was rediculous and causing a landfill problem, but the big manfacturers were happy I am sure to agree to a standard that pretty much requires wave soldering to avoid toasting the semiconductors. No more garage shop built first runs in Europe, no more Hewlett-Packard startups. I hope they don't extend this rule to the US. I'm already having to build my own car in the states to drive one that has a mechanical engine kill switch that doesn't lock the steering column. Some woman testified she couldn't even stall her Lexus by putting the transmission in reverse at 125 mph! Isn't it wonderful how the government rules protect us!
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 28th February 2010, 09:23 AM   #7
fotios is offline fotios  Greece
fotios's Avatar
This issue of RoHS compatibility has (well hidden from unrelated people with electronics industry) political dimensions, so a deeper examination of it will result in a kind of discussion which is prohibited from the rules of this forum.
Your reply and this of jcx are the most appropriate.
Fotios
Best Regards FOTIS ANAGNOSTOU
Old 28th February 2010, 09:50 AM   #8
fotios's Avatar
OTOH, my projects although are implemented with RoHS parts at whole (unfortunately i can't find non RoHS parts furthermore, which are by 5 - 10% less expensive ) in the end are not compatible with RoHS because i use in the assembly the old good 60/40 solder wire which melts at 180 degC instead the Pb free which melts usually at 270 degC.
Old 28th February 2010, 12:23 PM   #9
Charles Darwin is offline Charles Darwin  United Kingdom
You only saved 5-10% on non RoHS?
I bought a tube of 50 non RoHS OPA2134 for 0.78 each.
RoHS compliant OPA2134s run at 1.67 each!
Mind you it was the last tube they had.
Old 28th February 2010, 11:00 PM   #10
Pingrs is online now Pingrs  United Kingdom
Originally Posted by fotios View Post
... Pb free which melts usually at 270 degC.
More like 217 deg C (for usual SAC alloy)
Advice needed on RoHS regulationsHide this!Advertise here!
ROHS vs non-ROHS compliant components mtl777 Parts 4 24th January 2008 08:34 AM
eu volume regulations paddy Everything Else 1 12th July 2007 11:14 PM
Hello and advice needed jackpipe Introductions 1 17th March 2007 10:29 PM
Help and advice needed please.... smoothbreed Subwoofers 1 5th February 2007 11:11 AM
advice needed jimbones Full Range 6 9th November 2004 08:40 PM
