DC Servo MOSFET Amplifier
Old 7th February 2016, 10:16 AM   #591
jwilhelm is offline jwilhelm  Canada
Is there DC on the output when the input is shorted? Does the hiss go away with the input shorted?
Old 7th February 2016, 10:34 AM   #592
prasi is offline prasi  India
prasi's Avatar
DC offset with the i/p shorted is 0.6 mV. And yes, there is same amount of hiss even when i/p is shorted.
The hiss/hum I am talking about, to hear it, I need to be pretty close to the speaker ~10-15 cm.
Old 7th February 2016, 10:43 AM   #593
The thump is likely coming from your source. I have a cheap DA converter that does the same thing.
Hiss can be harder to locate. It could be oscillation. A scope reading of the noise helps.
Old 7th February 2016, 11:23 AM   #594
prasi's Avatar
Yes, you are right. The thump (during track change) gone when I changed the source (mobile). Funny thing, I had used the same source , for my previous builds w/o such a problem.
Old 7th February 2016, 11:37 AM   #595
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by prasi View Post
Tested the amp. sound is nice, neutral (only test speakers now). I didnt have proper ceramic caps, used 22p instead of 10 p across the MPSA B-C. The blue ceramic caps used are 1kV and dont know if they are suitable.
three problems,
1. there is hiss when sound is muted. should I remove the 2r2 ground lift and connect i/p ground directly to psu?
2. during changeover from one music track to next track, there is a thump noise.
3. minor problem is that there is a start thump, which a speaker delay will eliminate.
reg
Prasi
Nice work... remove 2R2 and connect input ground directly to psu ground.
Old 7th February 2016, 11:38 AM   #596
still4given is offline still4given  United States
still4given's Avatar
It still sounds like a grounding issue. Try running a wire from input ground to star ground and see if anything changes.
Old 7th February 2016, 03:33 PM   #597
prasi's Avatar
Removing the 2r2 and connecting i/p gnd to psu gnd solved the problem. There is still a minor hum when ear is next to woofer, but not audible even from 10cm away.
connected to proper speakers, slight start-up thump, other than that no unwanted behavior. sound is very nice. bass is good
Once I get correct value NPO/C0G caps, I will change to the recommended values and install rest of the pairs and listen again.
bias that I set-up is 32mV across the emitter resistor pair, everything is cool.
even with only single pair, with 32V supply, its loud !, even at very low pot volume setting. I can only imagine what will happen at 3 pairs, 70V .
reg
Prasi
Last edited by prasi; 7th February 2016 at 03:40 PM. Reason: supply voltage comment
Old 7th February 2016, 11:16 PM   #598
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Hello apexaudio
greetings F100 #30 schematic and FX100 #540 SCHEMATIC i see changes in
schematic values is #540 is it new modified schematic i want to use it with
2 pair AX14 my transformer 40 0 40 AC
warm regards
Andrew
"It's Better to try and fail than to never know and always wonder"
Old 9th February 2016, 11:57 AM   #599
apexaudio's Avatar
Start-up thump is from DC servo and this behavior is ok.
Old 9th February 2016, 12:44 PM   #600
prasi's Avatar
Thanks Mr. Mile for letting me know.
As I said I will install rest of the pairs, correct caps and then listen again.
Should I increase the bias, as these are MOSFETS. Currently, I have it at 32 mV across the emitter resistor pair.
reg
Prasi
DC Servo MOSFET AmplifierHide this!Advertise here!
To use DC servo or not? jaycee Solid State 43 13th March 2018 07:43 PM
DC blocking cap in feedback path or DC servo? roender Solid State 27 19th September 2007 09:40 AM
DC servo uli Chip Amps 20 3rd December 2004 11:40 AM
N-Channel mosfet amplifier with servo bias f4bok Solid State 14 22nd September 2004 06:32 PM
DC servo Bensen Solid State 0 23rd May 2003 11:34 AM
