DC Servo MOSFET Amplifier
I found two errors and fixed them. This has been tested and works well.
  • FX100 PSU with clip circuit errors.pdf
Some tracks missing...
Use this PSP100 for FX100 with 3 pairs.
Hi Mile,
I took your advice and built the PSP 100 PSU. I had to make a little daughter board to output +-15V for the XLR pre's. Here are some pics of it installed.
By the way, the protect LED is inverted in the file you shared in the post above.
I did a bit of a redraw to be able to use some euro blocks instead of all spade connectors.
Hi Mile,
I hope you are still monitoring this thread. With this PSP100 PSU the clipping circuit is a little too sensitive. The LEDs start flickering and a pretty low volume. They act more like VU lights than clip indicators. Are there some changes I can make so they don't flicker until clipping occurs?
Also, I was out of 0R33 2W resistors so I used 0R15. May I assume that these will affect the over-current circuit?
Thanks, Terry
Apex FX100 R22 to trim pot adjustment value
hi guys is been so long I'm just checking my Sprint file collection and I don't remember if this R22 was change by a pot and what value it was? also is this PSU good to go no changes? looks good 🙂
