DC Servo MOSFET Amplifier
Old 12th June 2012, 03:35 PM   #301
comasus is offline comasus  India
Originally Posted by apexaudio View Post
Yes, with 60-30-0-30-60v dc rail voltage.
Then how about power output?
I have 48-24-0-24-48 Transformer can i use it
Old 12th June 2012, 03:53 PM   #302
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Yes, but not for PA.
Old 13th June 2012, 09:50 AM   #303
R.I.P.
Coma,
are you aware of the difference between AC voltage and DC voltage.
It looks like post300 is referring to DC voltage: Is "this amp is suitable for 4ohms"?
and
post301 is referring to AC voltage: "I have 48-24-0-24-48 Transformer"
regards Andrew T.
Old 13th June 2012, 12:46 PM   #304
R.I.P.
Your posts stating ambiguous voltages do not show whether you understand or not.
regards Andrew T.
Old 21st June 2012, 06:34 PM   #305
suryadi5417 is offline suryadi5417  Indonesia
Schematics with correction.
LF411 can be used instead TL071 ?
Old 15th July 2012, 04:47 PM   #306
need correction.....
Old 18th July 2012, 08:12 AM   #307
apexaudio's Avatar
Yes, use LF411 instead TL071.
Old 22nd August 2012, 08:40 AM   #308
sanbadgujar is offline sanbadgujar  India
Hi apexaudio I want Clasic 120W RMS 8E amplifier. I have 30-0-30 5A transformer is it OK for 120 watts to 8E load I wanted parts list and can i use same pcb that you mention A100 please help if you required my emailid is sanbadgujar@gmail.com
Old 22nd August 2012, 06:39 PM   #309
apexaudio's Avatar
For 120W at 8E you need transformer 45-0-45 vac and you can use amp from this thread with 2 output pairs IRFP240/IRFP9240.
Old 23rd August 2012, 04:23 AM   #310
Hi Aperaudio thanks for help i have one dought in your #122 post from photo of circuit F100 i fell
nearly many registrar watts size is 1W can you mention all registrar watts size please thanks
DC Servo MOSFET AmplifierHide this!Advertise here!
To use DC servo or not? jaycee Solid State 43 13th March 2018 07:43 PM
DC blocking cap in feedback path or DC servo? roender Solid State 27 19th September 2007 09:40 AM
DC servo uli Chip Amps 20 3rd December 2004 11:40 AM
N-Channel mosfet amplifier with servo bias f4bok Solid State 14 22nd September 2004 06:32 PM
DC servo Bensen Solid State 0 23rd May 2003 11:34 AM
