DC Servo MOSFET Amplifier
Old 15th September 2010, 10:24 PM   #111
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by theerasak khan View Post
Hi Apex
I have a question for thisamp.
How many power supply and idle current adjusting?
Thank you.
PSU +/-56V 5A , bias 100mA per mosfet.
Old 15th September 2010, 10:34 PM   #112
theerasak khan is offline theerasak khan  Thailand
Hi Apex.
Do you have pcb. Thank
Old 15th September 2010, 10:45 PM   #113
apexaudio's Avatar
Hi Apex.
This is my very old amp (see post #99), there is no any files, but no need for new pcb design, just copy from old pcb.
Old 15th September 2010, 10:59 PM   #114
glazarou is offline glazarou  Greece
glazarou's Avatar
hmm..ok seems that ac analysis in this circuit cant work well or something else dont know..
i changed frequency manually from source and i got same output for all the bandwidth.... i was like WTF ...
Old 16th September 2010, 05:48 AM   #115
Tekko is offline Tekko
Banned
Never trust simulation! I've had things not work at all in simulation that have worked perfectly fine in reality and vice versa.
Old 16th September 2010, 05:57 AM   #116
ostripper is offline ostripper  United States
ostripper's Avatar
I differ... I have had things simulate well in multisim but lockup LTspice. The operators knowledge doing the simulation , the simulator itself ,and the models used will determine the accuracy of the simulation. I just had LT predict my OPS bias point within 1mv from the simulation to the real thing. I knew almost exactly where to set the trimmer to get my 70ma VBias beforehand, no guessing .
I have also simulated classic designs and the simulator predicted the bandwidth and THD within a few % of the OEM specifications ... again, I had to use accurate models that matched the OEM's specs.
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 16th September 2010, 07:15 AM   #117
glazarou's Avatar
Actually is not that multisim doing wrong but its difficult to understand its mind and how it calculate some things...
if i find time i will seperate the schematic into stages and i will see which stage doing this low-pass filter response....
i have already tested the opamp stage and i got clear response...
Old 16th September 2010, 08:43 AM   #118
apexaudio's Avatar
[QUOTE=glazarou;2303361]Apex seems i begin to love this amp ...the corrected clear schematic is this...
with different R14 values(tried 22k,30k,56k) and different supply voltage, circuit gave 50W-200W on 8ohm with great frequency response....
I like F100 and use it many times in the past, I wiil build new version. It's great sounding amp and great reability amp but not popular in DIY, I think diyers don't like use OP in amps.
Old 16th September 2010, 08:52 AM   #119
apexaudio's Avatar
I think if many diyers rebuild Japanese amps from 80' , why not I rebuild my old amps, it's simple and not expensive for DIY.
Old 26th September 2010, 11:01 PM   #120
apexaudio's Avatar
50W Amplifier schematic from Elektor.
DC Servo MOSFET AmplifierHide this!Advertise here!
To use DC servo or not? jaycee Solid State 43 13th March 2018 07:43 PM
DC blocking cap in feedback path or DC servo? roender Solid State 27 19th September 2007 09:40 AM
DC servo uli Chip Amps 20 3rd December 2004 11:40 AM
N-Channel mosfet amplifier with servo bias f4bok Solid State 14 22nd September 2004 06:32 PM
DC servo Bensen Solid State 0 23rd May 2003 11:34 AM
