Double transistors in the VAS Why?
Old 25th February 2010, 09:47 AM   #1
GEirin is offline GEirin  Argentina
Default Double transistors in the VAS Why?
Hi all.
I`m interested to know the VAS of the Harman Kardon powers amplifiers.
Why has two transistors in paralllel? Q417-421 and Q419-423.
Has any advantage? Is better
Old 25th February 2010, 09:59 AM   #2
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
feed-forward feedback is taken from the front pair IIANM...
q417,419.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 25th February 2010, 10:26 AM   #3
bocka is offline bocka  Germany
Originally Posted by GEirin View Post
I`m interested to know the VAS of the Harman Kardon powers amplifiers.Why has two transistors in paralllel? Q417-421 and Q419-423.
Probably because of limiting the power dissipation of each transistor
Old 25th February 2010, 10:34 AM   #4
AKSA is offline AKSA  Australia
#3 is correct. Smaller devices, sharing the current, will have lower parasitic capacitances and be faster. This has profound impact on the sound quality.
Modern devices like the 2SC3423 will run higher currents - up to 15mA with ease - so two devices may no longer be needed.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 25th February 2010, 11:18 AM   #5
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
If just so, then why use a parallel pair in the Vas and a higher power device with nearly identical specs as driver ?
BJTs for VAS Stages
(= $6000 msrp Class A amp)
Vas : 2SA1145/2SC2705
Driver : 2SA1360/2SC3423
http://www.toshiba.com/taec/componen...c//66/7580.pdf
http://www.toshiba.com/taec/componen...nc/66/7540.pdf
Old 25th February 2010, 02:41 PM   #6
Hi
Thanks, very much for yours replies.
My question: for sound quality, is better, 1 transistor or parallel pair in VAS?
Guillermo
Old 25th February 2010, 04:56 PM   #7
Havenwood is offline Havenwood  Argentina
Havenwood's Avatar
Send a message via MSN to Havenwood
What about the impedance (input and output) in VAS?
Zin and Zout decrease.
Zin lower is bad?
For parasitic capacitances, VAS Cascode fix this.
What is Vce optimal? 5V?
- Music by John Williams -
Old 25th February 2010, 09:08 PM   #8
If you use an EF to drive the VAS, you will pick up about 2dB lower H2 and 15dB lower H3 with no change to other artefacts at +20dBU and 1KHz. For very large output stages, a buffer on the VAS is a good idea too.
For domestic amps, I've never found any benefit with a buffer after the VAS.
Jacco,
Bloody good question.....
Hugh
www.aksaonline.com
Double transistors in the VAS Why?Hide this!Advertise here!
About VAS and drivers transistors gaetan8888 Solid State 80 23rd September 2010 02:38 AM
VAS transistors ChocoHolic Solid State 44 9th July 2010 08:00 PM
the Double Diamond VAS Stee Solid State 4 9th January 2010 03:07 PM
High voltage transistors for VAS stage rtarbell Parts 4 15th November 2005 12:13 AM
