Old 25th February 2010, 12:15 AM   #1
srinath is offline srinath  United States
Default Just got me a realistic STA 2080
Well my ss amp made all the speakers sound well smeared and indistinguishable from one another, a tin can fisher and a good wharfedale both sounded about the same.
So realistic 2080 how is it.
Is there any mods for getting it to be better, and is there a standard check I have to do and replace cos its 30 years old.
It has 1 light out on one of the face dials - the signal strength one if I recall. Light only, the meter works.
Cool.
Srinath.
Old 25th February 2010, 02:00 AM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default Ol' gear...
Nice find snagging your STA.
I sold Realistic gear when it was in its heyday (Seventies).
Radio Shack contracted out with Pioneer and I believe Sansui and Kenwood.
My best guess is yours is a Kenwood based unit. These series of receivers are robust & virtually indestructable.
I would suggest getting the correct lamp for your meter(Maybe hard to find), and quite probably she needs some new Power Supply capacitors, as they are thirty years old now.. Don't be tempted to crank up the values on the capacitors....but you can bump up the VOLTAGE values.... no harm done. Don't be afraid to spend a little extra for "name brand" caps.....just don't over do it.
A technician could dial in your tuner...but you can do the rest.
__________________________________________________ ___Rick......
Old 25th February 2010, 03:14 AM   #3
Oh well, its not working on the right channel.
Both A and B dont have wattage to the right.
I guess I open it now, and see what it looks like.
Cool.
Srinath.
Old 25th February 2010, 03:31 AM   #4
Opened the right side, man is there a ton of stuff in there.
So where is the right channel outputs ? Assuming that is the likely spot of problem.
Cool.
Srinath.
Old 25th February 2010, 05:22 AM   #5
Ok I figured it out (yes operator error - sorta).
That cross bridge between the pre out and right was not there ... I swapped it from the left to the right pins and voila, only right, no left.
So I need a hanger wire bent into that shape ?
Cool.
Srinath.
Old 25th February 2010, 08:01 AM   #6
frugal-phile(tm)
planet10's Avatar
Cool.
Srinath.
Just make yourself a short RCA-RCA patch cable. It will likely sound better than the folded steel,
There is a whole lot you can do to soup this puppy up... as Richard suggests you start with elecos. Modern caps are better than vinatge, and those old resistors drift in value.
But before doing any but basic main you need a schema (even if you make it yourself) so you can decide what to do. Also whether you want to "restore" it and maintain collectors value, or you want to make it the best it can be.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th February 2010, 08:16 AM   #7
frugal-phile(tm)
planet10's Avatar
We need pictures... Google only turns up a SS STA-2080
like this SEVENTIES STEREO: REALISTIC STA-2080
dave
Old 25th February 2010, 01:30 PM   #8
I think I need it to be the best it can be, however I opened it and I find it really scary. Solid state stuff, like my 60 inch tv didn't look this bad. This was painfully cluttered inside it.
I have found pics of it on line, but I'll post pics of mine.
Thanks for the ideas.
Cool.
Srinath.
Old 25th February 2010, 04:02 PM   #9
kevinkr's Avatar
Worked for Radio-Shack part time in the 1970s and early 1980s - The STA-2080 is solid state and probably represents one of the better receivers they oem'd. This should be posted over in the solid state forum..
www.kta-hifi.net
Old 25th February 2010, 05:59 PM   #10
Gaaa I thought it was tube. Sheesh ... I was looking for tube and feeling all smug I got this one.
Sorry mods, please move it to tube forum.
Cool.
Srinath.
Monarch STA-100X Refurb wrenchone Tubes / Valves 7 19th September 2009 06:33 PM
Genexxa STA-2170 John Ball Chip Amps 0 22nd December 2007 12:15 PM
FS: Realistic STA-2500 receiver Jimmy154 Swap Meet 0 19th October 2006 03:43 PM
Realistic STA-2000 repair muskgrave Parts 11 27th December 2005 07:46 PM
Realistic STA-7 receiver rpapps Solid State 8 17th May 2005 01:49 AM
Page generated in 0.11147 seconds (78.17% PHP - 21.83% MySQL) with 10 queries
