MOSFET Amplifier IRFP240/IRFP9240
Old 10th December 2012, 02:25 PM   #691
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
replace 470R trim-pot with 1k trim-pot and than adjust bias as you wish,or
yesterday i did some mesurments at home with APEX HV23 at about 11,5Ohm resistor. it has given to me 45V/3,55A , 48V/4,05A and 51V/4,33A without clipping. at 53V there was 4,5A but clipping appeared. this all was at 1kHz frequency from signal-generator and lasted for about 15sec per measuring voltage/current. i did about ten this mesuraments so the amp was really taken to itīs maximum limits. it has got heated up but not so much more than it gets when it reaches itīs working temperature. it has only been left to find someone willing to share itīs loudspeakers with my amplifier to test it "live" and with music program instead tone-generator.
Old 12th December 2012, 07:33 AM   #692
Shelah is offline Shelah  Zambia
so in other words, 30-50mA is the range to bias if the trimpot is 1k? and also the voltage i intend to use is 44-0-44 ac. i know power will be lower than the expected but its worth the try.
Old 12th December 2012, 07:59 AM   #693
44250's Avatar
not in my case because i have +/-75V supply. i can adjust it to a 100mA per pair but i don't have heatsinks to cool it down,also it sounds the same with 15 and 100mA bias so why to exaggerate.
i don't know how much power you will get with +/-63V supply,but it is to be expected about 200W/8R and 300W/4R load. let us know when you measure!
Chop your own wood and it will warm you twice
Old 13th December 2012, 06:44 AM   #694
thanks 44250. let me see how it performs.
Old 13th December 2012, 07:04 AM   #695
44250's Avatar
i am expecting some good news!
Old 9th January 2013, 04:16 PM   #696
44250, i need the bias proceedure. things like initial values of resistances before and other information that i may need in this area.
Old 4th February 2013, 10:28 AM   #697
i present to you DIY apex HV23.
Old 4th February 2013, 02:51 PM   #698
HighTec is offline HighTec  Croatia
HighTec's Avatar
Shelah, you don't need fans with those huge heatsinks!
Old 4th February 2013, 02:56 PM   #699
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
It depends on how long it is switched on for and if the case has openings for airflow.
I used a similar setup in a pc case and after a couple of hours of high power I couldn't bear my hand on the pc case. So I fitted a couple of fans and it was fine after that.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 4th February 2013, 02:57 PM   #700
wattaniya is offline wattaniya
hardwork. good heatsink.
what purpose u made with vero board?
MOSFET Amplifier IRFP240/IRFP9240Hide this!Advertise here!
IRFP240&IRFP9240 power amplifier schematic mos Solid State 31 26th June 2012 08:21 AM
IRFP240 / IRFP9240 MOSFETs danieljw Swap Meet 8 4th July 2009 01:51 AM
Wtb: Irfp240 / Irfp9240 folkeb Swap Meet 1 10th March 2009 10:18 AM
IRFP240 + IRFP9240 -- pairs jackinnj Swap Meet 1 2nd June 2006 02:22 AM
IRFP240 and IRFP9240 Wanted richeros Swap Meet 1 9th November 2002 12:38 PM
