MOSFET Amplifier IRFP240/IRFP9240 - Page 68 - diyAudio
Old 12th November 2012, 07:03 PM   #671
apexaudio's Avatar
Originally Posted by Bogdi12001 View Post
Hello.
This amplifier can be powered from a +/-93v supply?
Thanks.
No, +/-80V is maximum.
Old 22nd November 2012, 02:38 AM   #672
hi apex sir,
i set preset to 2vdcv on 10 ohm rail 10w resitor. why the emiter resistor value is different from one one? emiter resitors showing voltage 10mv,4.5mv,15mv,0mv like this.
Old 22nd November 2012, 06:56 AM   #673
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
Originally Posted by nazirdigi View Post
hi apex sir,
because of diferent hFE of output transistors,that is the reason why the emitor resistors are used. if they were matched (Ibe /Ie for bipolar or Ugs/Is for fet) before soldiering at pcb than this voltages would be the same and emitor resistors would not be needed.
please someone correct me if im wrong.
Old 22nd November 2012, 10:22 AM   #674
Your wrong !
Can't be hFE. They are mosFETs
mosfet-amplifier-irfp240-irfp9240
If they were BJTs, then it's variation in Vbe that leads to be variations in Ic and shows when reading the individual Vre (voltage across the emitter resistor).
For mosFET output stage it's variation in Vgs that leads to even bigger variations in Id and that shows when reading individual Vrs (voltage across the source resistor).
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd November 2012, 10:44 AM   #675
44250's Avatar
Originally Posted by AndrewT View Post
Your wrong !
Can't be hFE. They are mosFETs.
thank you for correcting me.
Old 22nd November 2012, 10:49 AM   #676
and that variation in Vgs for paralleled mosFETs is why it is absolutely important that devices be selected for very close Vgs at the target operating current for the amplifier output stage.
regards Andrew T.
Old 22nd November 2012, 10:55 AM   #677
44250's Avatar
and that variation in Vds for paralleled mosFETs is why it is absolutely important that devices be selected for very close Vds at the target operating current for the amplifier output stage.
Vds or Vgs?
Old 22nd November 2012, 10:57 AM   #678
Sorry. Yes, Vgs
regards Andrew T.
Old 22nd November 2012, 11:25 AM   #679
44250's Avatar
Thumbs up 0k
its 0k Andrew,we learn with you!
Old 22nd November 2012, 11:26 AM   #680
No,
I get accused of being unhelpful.
regards Andrew T.
IRFP240&IRFP9240 power amplifier schematic mos Solid State 31 26th June 2012 08:21 AM
IRFP240 / IRFP9240 MOSFETs danieljw Swap Meet 8 4th July 2009 01:51 AM
Wtb: Irfp240 / Irfp9240 folkeb Swap Meet 1 10th March 2009 10:18 AM
IRFP240 + IRFP9240 -- pairs jackinnj Swap Meet 1 2nd June 2006 02:22 AM
IRFP240 and IRFP9240 Wanted richeros Swap Meet 1 9th November 2002 12:38 PM
Copyright 1999-2017 diyAudio
