Old 13th June 2012, 05:39 PM   #631
hi comasus,
can u tell me how u check dc protect and thermal protect working or not, i already checked. but how u did?
what is the relay delay time when on and off.
can u post some images top and bottom pcb
Old 13th June 2012, 11:31 PM   #632
Wall Photos | Facebook anyone have the pcb, please share, i want try this HYBRID....
Old 14th June 2012, 06:22 AM   #633
comasus is offline comasus  India
Originally Posted by nazirdigi View Post
hi comasus,
I have checked it by giving 2vdc by DMM
and used solder for ntc
turn on delay is not working
i have inserted in the speaker box with the amplifier so for the images i have to remove the cover again
expect turn on delay remaining is perfect so i have kept it inside confidently
Old 14th June 2012, 07:39 AM   #634
how u make the pcb? toner transfer method or silkscreen. which layout u followed.
u said turn on delay is not working. then why u put inside the speaker box, can u share some images. top and bottom pcb.
Old 15th June 2012, 08:43 AM   #635
Toner transfer
Followed attached image
I posted my problem but no help and compromised having dc protect
I put inside the speaker as the amplifier was fitted in it
Old 15th June 2012, 05:31 PM   #636
Old 16th June 2012, 06:22 AM   #637
It will take some time
Old 25th June 2012, 06:37 PM   #638
Originally Posted by apexaudio View Post
Simple Full Complementary Simetry +/-80V. Voltage amplifier/driver biased with 30mA. This driver circuit stabilized BIAS in output stage. Exelent stability without oscilation, hum and noise, sound great.
RMS Power: 240W 8ohm, 350W 4ohm
thanks for sharing projects
this a great
MOSFET amplification
Old 25th June 2012, 06:51 PM   #639
Send a message via Skype™ to mohsin0702051
Originally Posted by event horizon View Post
If you had used Lateral Mosfets in the output stage then i guess you could get away with such a simple biasing scheme. Lateral Mosfets have a negative temperature coefficient so they'll tend to reduce quiescent current as they heat up.
IRFP240 & it's complement have a positive temp coefficient (until they are drawing many Amps of current) so they'll conduct more current as they heat up. There is no allowance for this in your circuit diagram, you'd need something similar to what is used in a transistorised output stage.
I might be wrong, but i don't think so
hello,i have an problem.i use microcontroller to switch mosfet(IRF840) in boost converter but when i connect the microcontroller its output decreasing thats why it cannot switch this mosfet.so how can i remove this loading problem,plz
Old 25th June 2012, 07:04 PM   #640
hello,i have an problem that to switch mosfet(IRF840) in boost converter by microcontroller .when i connect the microcontroller to mosfet thats the output of the microcontroller out put goes to 5v to 2.5 v(apporiximately) due to loading effect.how can i remove this loading problem.plz anyone
IRFP240&IRFP9240 power amplifier schematic mos Solid State 31 26th June 2012 08:21 AM
IRFP240 / IRFP9240 MOSFETs danieljw Swap Meet 8 4th July 2009 01:51 AM
Wtb: Irfp240 / Irfp9240 folkeb Swap Meet 1 10th March 2009 10:18 AM
IRFP240 + IRFP9240 -- pairs jackinnj Swap Meet 1 2nd June 2006 02:22 AM
IRFP240 and IRFP9240 Wanted richeros Swap Meet 1 9th November 2002 12:38 PM
Copyright ©1999-2013 diyAudio
