MOSFET Amplifier IRFP240/IRFP9240 - Page 52 - diyAudio
Old 13th March 2012, 06:18 AM   #511
yes, the led blinks 5 times.
Old 13th March 2012, 12:20 PM   #512
hi apex sir,
pls can u share this class h pcb layout. top and bottom in pdf..
Old 16th March 2012, 12:24 PM   #513
Originally Posted by apexaudio View Post
This circuit suply 12V DC Fan activated by signal present on amp out, very simple without NTC on heatsink.
hi apex sir,
any substitute for bd902, hard to find in shops.
Old 16th March 2012, 10:27 PM   #514
apexaudio's Avatar
Originally Posted by nazirdigi View Post
hi apex sir,
Any PNP TO220 darlington can be use instead BD902
Old 17th March 2012, 08:27 AM   #515
apex sir,
i found some substitutes for bd902, is this all compatible?
bd241c ,bdw94c , tip127 , tip107 ,tip137 . tip42c.?
Old 17th March 2012, 09:11 AM   #516
astankov's Avatar
BD241 and TIP42C are not darlingtons even BD241 is NPN so they are not suitable but bdw94c , tip127 , tip107 ,tip137 seems to be OK for substitution.
Regards!
Old 17th March 2012, 09:19 AM   #517
thanks astankov for the reply.
Old 17th March 2012, 09:44 AM   #518
apexaudio's Avatar
hi apex sir,
This class H can't work with 5 pairs of outputs, but is ok for single pair like in H200 (post #88)
DC Servo MOSFET Amplifier
Old 20th March 2012, 04:40 AM   #519
hi apex sir ,
i made the fan control ,
1- is this work with amp input?, not the output,any suggestion to work with input signal,
2- the fan is not working with maximum speed, i provide ac 12v, i checked fan output, it is showing 8vdc, any suggestions.
thank u.
Old 20th March 2012, 08:19 AM   #520
apexaudio's Avatar
hi apex sir ,
thank u.
Fan control can't work with amp input, use unregulated 15-18vdc for suply.
IRFP240&IRFP9240 power amplifier schematic mos Solid State 31 26th June 2012 08:21 AM
IRFP240 / IRFP9240 MOSFETs danieljw Swap Meet 8 4th July 2009 01:51 AM
Wtb: Irfp240 / Irfp9240 folkeb Swap Meet 1 10th March 2009 10:18 AM
IRFP240 + IRFP9240 -- pairs jackinnj Swap Meet 1 2nd June 2006 02:22 AM
IRFP240 and IRFP9240 Wanted richeros Swap Meet 1 9th November 2002 12:38 PM
Copyright 1999-2017 diyAudio
