MOSFET Amplifier IRFP240/IRFP9240
Old 11th March 2012, 04:17 AM   #501
ravpreet420 is offline ravpreet420
Default apex 555 protection pcb size ?
Originally Posted by apexaudio View Post
Simple Soft-start, DC, Thermal and Overload Protect with NE555. Use single 12vac for suply.
pcb size ?
Old 11th March 2012, 07:28 AM   #502
wattaniya is offline wattaniya
hi ravpeet the size is,
41mm - 61mm
Old 11th March 2012, 08:43 AM   #503
thanx nazirdigi
Old 11th March 2012, 10:46 AM   #504
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by nazirdigi View Post
hi apex sir,
now i put 10k ntc .
now the protect circuit is working, but when power on , the relay delay time is one second ,because the led indicator only blinking once and after relay connects the led permanently lights on, how can i increase the delay time to 3 or 5 seconds?
Replace cap 1uF with 10uF or 680k with 2,2M and delay time will increase.
Old 11th March 2012, 10:50 AM   #505
thanks apex sir for the reply
Old 11th March 2012, 04:53 PM   #506
i changed the 1uf cap with 10uf , the delay time is 10seconds, and i change it to 2.2uf but delay time 2seconds, tommorow i'll buy 4.7uf and i'll check it.
Old 12th March 2012, 08:16 AM   #507
adeel is offline adeel
apex sir,
send me psu-10 pcb pdf file
thanks
regards
Old 12th March 2012, 10:32 AM   #508
hi apex sir,
today i change to 4.7uf cap, and its worked perfect, delay time is 5second,
thanks for the pcb.
Old 12th March 2012, 02:51 PM   #509
apexaudio's Avatar
hi apex sir,
thanks for the pcb.
Delay time is 1second per 1uF
Old 12th March 2012, 09:39 PM   #510
apexaudio's Avatar
...the led indicator blink 5 times (1Hz)?
MOSFET Amplifier IRFP240/IRFP9240Hide this!Advertise here!
IRFP240&IRFP9240 power amplifier schematic mos Solid State 31 26th June 2012 08:21 AM
IRFP240 / IRFP9240 MOSFETs danieljw Swap Meet 8 4th July 2009 01:51 AM
Wtb: Irfp240 / Irfp9240 folkeb Swap Meet 1 10th March 2009 10:18 AM
IRFP240 + IRFP9240 -- pairs jackinnj Swap Meet 1 2nd June 2006 02:22 AM
IRFP240 and IRFP9240 Wanted richeros Swap Meet 1 9th November 2002 12:38 PM
