Old 1st February 2012, 12:56 AM   #491
thanks sir for the quick reply.
Old 1st February 2012, 03:06 AM   #492
Originally Posted by apexaudio View Post
No, PRO pins are not compatible on H900 and HV23, but if you don't want use overload protect you can use this protect with any amp.
I've built your HV 350 PSU,can I use it for B500??
Does it protector will working good??
Old 10th March 2012, 08:57 AM   #493
apexaudio's Avatar
Yes, but without overload protect,
Old 10th March 2012, 11:04 AM   #494
hi apex sir,
i finished and tested this protect, but not working,
what will be the problem?
Old 10th March 2012, 11:20 AM   #495
apexaudio's Avatar
Originally Posted by nazirdigi View Post
hi apex sir,
Protect can't work without 10k NTC (thermal protect), but you can use 10k resistor instead NTC for test.
Old 10th March 2012, 11:43 AM   #496
thanks sir for the reply.
ok i will buy 10k ntc and check.
Old 10th March 2012, 01:21 PM   #497
hi apex sir,
now i put 10k ntc .
now the protect circuit is working, but when power on , the relay delay time is one second ,because the led indicator only blinking once and after relay connects the led permanently lights on, how can i increase the delay time to 3 or 5 seconds?
Old 10th March 2012, 02:42 PM   #498
aman khalsa's Avatar
hi apex sir,
hello sir ..can u pls share pcb lay out and digram..???. thank u...
Old 10th March 2012, 02:51 PM   #499
hi khalsa check post no 475.
Old 10th March 2012, 05:19 PM   #500
hi apex sir,
now i put 10k ntc .
IRFP240&IRFP9240 power amplifier schematic mos Solid State 30 19th October 2009 12:45 PM
IRFP240 / IRFP9240 MOSFETs danieljw Swap Meet 8 4th July 2009 01:51 AM
Wtb: Irfp240 / Irfp9240 folkeb Swap Meet 1 10th March 2009 10:18 AM
IRFP240 + IRFP9240 -- pairs jackinnj Swap Meet 1 2nd June 2006 02:22 AM
IRFP240 and IRFP9240 Wanted richeros Swap Meet 1 9th November 2002 12:38 PM
Page generated in 0.06898 seconds (82.93% PHP - 17.07% MySQL) with 11 queries
