#431 |
#432 |
Well, Pro is short term of Protection. It's an over-current detector and in case of short circuit on the output, it sends the error signal to the protection board.
#433 |
thank you very much HighTec
#434 |
My email id bushulo@gmail.com if someone could kindly send me the gerber files or pdf of HV350.2 PCB layout.
Thank |
#435 |
dear bushulo,
do you have obtain gerber files or pdf of hv350.2 pcb.i live in lucknow by this locotion i came to know that you belong to goa .i recently make a tour for goa,staid at hotel goa international in panji at meer mar beach.by the way it is very pleasant city i am too impressed with this city.my English is poor plz not mention.thanking you.my e mail is alvi.masood251@gmail.com |
#436 |
Hello Mile,
Could you explain working of circuit in post 383 so we can adapt it to other amplifiers? How is the overload/short circuit detected? What current? Regards, Victor |
#437 |
hello, is it safe to use 2x63V for 3 pairs of IRFP240/9240? This should give about 250W to 4 ohms. There is no problem at 1khz and 10khz, but when we go close to limitation at 100hz in 4 ohms, then all IRFP240 burn. Maybe these transistors are fake?
#438 |
3pr of 240/9240 adds up to ~900W of output devices.
Divide by 4 for MosFETs and you get ~225. Your target of 240W into 4r0 is close enough to 225 to be considered as reliable. However, your target of 240W and +-63Vdc do not seem compatible ! |
#439 |
output stage is powered with 2x63V and input stage with 2x70V
#440 |
I get 300W to 320W from +-58.5Vdc supply rail using BJT output stages.
A mosFET output stage may require upto 5V more on the supply rails to achieve that 300 to 320 target. But you are showing a target of "only" 240W from supply rails that are 4.5V higher. That seems odd. |
| IRFP240&IRFP9240 power amplifier schematic | mos | Solid State | 31 | 26th June 2012 08:21 AM |
| IRFP240 / IRFP9240 MOSFETs | danieljw | Swap Meet | 8 | 4th July 2009 01:51 AM |
| Wtb: Irfp240 / Irfp9240 | folkeb | Swap Meet | 1 | 10th March 2009 10:18 AM |
| IRFP240 + IRFP9240 -- pairs | jackinnj | Swap Meet | 1 | 2nd June 2006 02:22 AM |
| IRFP240 and IRFP9240 Wanted | richeros | Swap Meet | 1 | 9th November 2002 12:38 PM |
| Page generated in 0.22241 seconds (100.00% PHP - 0% MySQL) with 10 queries |
