MOSFET Amplifier IRFP240/IRFP9240
Old 14th July 2010, 03:38 PM   #291
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Default Hv23 bias compensation
Originally Posted by apexaudio View Post
I dont use this PCB in a last 2 year (repleced with H class in PA and A class for home aplication), but I must build couple PCBs again and try to see the effect on some sugestion.
I set bias to 200mA, after 10min. amplifier was hot and bias decrease to 120mA. That's the fact for people who don't belive that HV23 have thermal stability. Thermal compensation with transistor in new version is need for do not underbiased not for overbiased amp.
Old 14th July 2010, 04:57 PM   #292
udhay_cit is offline udhay_cit  India
Look nice, but you must put driver transistors on heatsink with outputs, drivers work with 30mA bias and must be on heatsink. Better use some TO220 for drivers.
Yes thank you. But i already mention this is only for testing and now i am not using this amplifier. I am doing PCB work for final design,after that i will attach to heat sink and i didn't select an output transistor yet but i am thinking about MJE15032 & 33. What is your suggestion......
MJE15032 & 33 are not available in my city. It is only available in DIGIKEY. So may i use MJE350 & 340. It's get heat little more then output driver MOSFET(for +/-33 supply). Is it happen normally or anything wrong?
Old 14th July 2010, 06:17 PM   #293
apexaudio's Avatar
Originally Posted by najjachi View Post
hi apex it's me agin. can you post new picture of PCB of HV350.2 for print because some points on the PCB are in brown color example the points of the output transistors.
Regards.
OK?
Old 14th July 2010, 06:30 PM   #294
ashok is offline ashok
ashok's Avatar
Originally Posted by udhay_cit View Post
...........MJE15032 & 33 are not available in my city. ..............
Go through an EFY ( Electronics For You ) magazine and contact parts suppliers from Mumbai and Bangalore . All you need to do is send an email and request for the part you want. You can get it fairly easily I think. Many suppliers respond to email requests now. Shipping isn't expensive.
AM
Old 14th July 2010, 09:33 PM   #295
Tube Pro is offline Tube Pro  Macao
Tube Pro's Avatar
Default Pcb
Simple Full Complementary Simetry +/-80V. Voltage amplifier/driver biased with 30mA. This driver circuit stabilized BIAS in output stage. Exelent stability without oscilation, hum and noise, sound great.
RMS Power: 240W 8ohm, 350W 4ohm
Hi Mile,
Do you have the PCB of this 10 mosfets amp project?
HV23? Post #1
Thanks,
Joel
Old 14th July 2010, 10:56 PM   #296
najjachi is offline najjachi
it's ok. thanks
Old 15th July 2010, 07:46 PM   #297
apexaudio's Avatar
Originally Posted by Tube Pro View Post
Hi Mile,
HV23? Post #1
Thanks,
Joel
Yes, but I not recomand to use +/-90V with IRFP240/IRFP9240, no metter if U use 5 or more pairs mosfets,
Old 16th July 2010, 07:05 AM   #298
Tube Pro's Avatar
How about +/- 80vdc for 5 pairs IRFP240/IRFP9240?
What's Pout @ 8 ohms?
Thanks,
Joel
Old 16th July 2010, 07:19 AM   #299
apexaudio's Avatar
Thanks,
Joel
275W/8R
Old 16th July 2010, 07:35 AM   #300
mathez is offline mathez  Indonesia
what instead for IRFP240/IRFP9240?out of stock here
MOSFET Amplifier IRFP240/IRFP9240Hide this!Advertise here!
IRFP240&IRFP9240 power amplifier schematic mos Solid State 31 26th June 2012 09:21 AM
IRFP240 / IRFP9240 MOSFETs danieljw Swap Meet 8 4th July 2009 02:51 AM
Wtb: Irfp240 / Irfp9240 folkeb Swap Meet 1 10th March 2009 11:18 AM
IRFP240 + IRFP9240 -- pairs jackinnj Swap Meet 1 2nd June 2006 03:22 AM
IRFP240 and IRFP9240 Wanted richeros Swap Meet 1 9th November 2002 01:38 PM
