Old 11th July 2010, 04:20 PM   #281
Hi the HV350 amp working for me with single pair of MOSFET and +/-33V. It's only for testing. I am going to construct the full function amplifier....
But the Toshiba transistors are not available in my nearest stores. for testing now i am using 2N5401&2N5551 instead of 2SA970&2SC2240. For other two complementary pairs i am using MJE340&MJE350 (sorry its only for testing). The amp works good but i want to match the perfect complementary pair for all the Toshiba transistors.
The transistor terminal changes not a problem, i will make the correction in my PCB design. My question is may i replace the 2SA970&2SC2240 pair with 2N5401&2N5551 permanently. What should be the equivalent transistors for other pairs and it should be easily available in market. Please give me a solution. Thank you.
Udhay
Old 11th July 2010, 05:46 PM   #282
apexaudio's Avatar
Udhay
I try to use most available parts, and use design witch performance is independent of special parts. 2SA/2SC can be permanently replace with 2N, and you can replace other transistor, but try to maching hfe for simetry,
Old 11th July 2010, 09:08 PM   #283
apexaudio's Avatar
Can you post pictures, and what speakers you use?
Old 11th July 2010, 10:43 PM   #284
apexaudio's Avatar
Originally Posted by mihailo View Post
Thanks.
I need schematics because I don't know where to connect output,voltage,...
it's not marked on pcb.
This can help...
Old 12th July 2010, 01:17 PM   #285
mihailo is offline mihailo  Serbia
Thank you so much Apex.
I'LL do PCB tomorrow, and post pictures.
Old 12th July 2010, 02:05 PM   #286
I have a few questions about PSU-7.
What is it ? (features)
Where is the bottom side of the PCB, to make one.
Thanks,
Cambe
Old 12th July 2010, 03:15 PM   #287
apexaudio's Avatar
Thanks,
Cambe
Post #122
Old 14th July 2010, 11:14 AM   #288
Sorry for the very low quality pictures....
I am using DAINTY WOOFER
12" - 8Ω / ~240W
Old 14th July 2010, 01:30 PM   #289
hi apex it's me agin. can you post new picture of PCB of HV350.2 for print because some points on the PCB are in brown color example the points of the output transistors.
Regards.
Old 14th July 2010, 02:24 PM   #290
apexaudio's Avatar
12" - 8Ω / ~240W
Look nice, but you must put driver transistors on heatsink with outputs, drivers work with 30mA bias and must be on heatsink. Better use some TO220 for drivers.
IRFP240&IRFP9240 power amplifier schematic mos Solid State 31 26th June 2012 08:21 AM
IRFP240 / IRFP9240 MOSFETs danieljw Swap Meet 8 4th July 2009 01:51 AM
Wtb: Irfp240 / Irfp9240 folkeb Swap Meet 1 10th March 2009 10:18 AM
IRFP240 + IRFP9240 -- pairs jackinnj Swap Meet 1 2nd June 2006 02:22 AM
IRFP240 and IRFP9240 Wanted richeros Swap Meet 1 9th November 2002 12:38 PM
Copyright ©1999-2013 diyAudio
