MOSFET Amplifier IRFP240/IRFP9240
Old 24th June 2010, 08:17 PM   #261
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Originally Posted by apexaudio View Post
With +/-33V single pair of output FETs is enough, you can see circuit in post #239, and wireing in post #145. Bias adjust to get about 20mV on 0R47/5W resistor. Power will be about 50W on 8R load with +/-33V DC. You can use this amp for any aplication, and I think beginer can build it with my help.
You have to take into consideration transients when deciding on a power supply.
On my first self design MOSFET amp I used +/-40VDC and was surprised how quickly the transients got clipped.
I now never use a supply less than +/-60VDC.
I do play quite loud so perhaps you dont need such a high voltage.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 24th June 2010, 08:27 PM   #262
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
I suggest +/-75V. Amplifier with +/-33V can be realise with LM3886 or TDA7294.
Old 27th June 2010, 09:45 PM   #263
apexaudio's Avatar
Default Hv350.2
HV350 with cut out protect
Old 30th June 2010, 12:38 PM   #264
apexaudio's Avatar
VI limiter, and cut out protect from HV350.2 can be add on all my amps.
Old 1st July 2010, 11:58 AM   #265
mihailo is offline mihailo  Serbia
Apex, can you look this chematics.
If it is ok, I would draw pcb for this because I have loot of IRFP250N fets.
File Type: gif 1NBMei-d11e7edee78485801ab1a36405806c28.gif (57.5 KB, 1852 views)
Old 1st July 2010, 12:13 PM   #266
apexaudio's Avatar
Better buy same number of IRFP9240 and build HV350,
Old 4th July 2010, 02:18 PM   #267
najjachi is offline najjachi
Hi apex, do you have PCB of HV350.2 with cut out protection?
Old 4th July 2010, 04:14 PM   #268
apexaudio's Avatar
Old 4th July 2010, 08:41 PM   #269
Thanks, but i was mean the other PCB so how i'll be able to print and build the amplifier
Old 4th July 2010, 10:04 PM   #270
apexaudio's Avatar
Default Hv350.2 pcb
PCB size: 200x50mm
MOSFET Amplifier IRFP240/IRFP9240Hide this!Advertise here!
IRFP240&IRFP9240 power amplifier schematic mos Solid State 31 26th June 2012 08:21 AM
IRFP240 / IRFP9240 MOSFETs danieljw Swap Meet 8 4th July 2009 01:51 AM
Wtb: Irfp240 / Irfp9240 folkeb Swap Meet 1 10th March 2009 10:18 AM
IRFP240 + IRFP9240 -- pairs jackinnj Swap Meet 1 2nd June 2006 02:22 AM
IRFP240 and IRFP9240 Wanted richeros Swap Meet 1 9th November 2002 12:38 PM
