Class A electronics ban?? fact or fiction
Old 3rd April 2010, 01:42 PM   #71
Andrew Eckhardt is offline Andrew Eckhardt  United States
"although this stuff is simply not used in consumer grade equipment"
I should probably take that back. I would not be surprised at all to find some form of ECL in the latest gaming graphics cards. In your laptop, no.
Old 1st February 2013, 09:19 AM   #72
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
99.9% of all audio is Class A.
The "Elsinore Project" DIY Speaker System & DIY "Trans-Amp" - 40 Watt Transconductance Amp
- "Don't take anything I say as an affirmation, but as a question." Niels Bohr
Old 1st February 2013, 09:45 AM   #73
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Well my 100W Class A amp offsets its running costs by my not needing the heating up so high.
Also nearly all line level amplification is Class A.
Old 1st February 2013, 07:53 PM   #74
rsavas is offline rsavas  Canada
If anyone would be putting forth such a ruling, it would be the US DOE!! Look them up and look for yourself. These CFR documents are a real pain in the a$$ to read.
So as a work around, sell your Class-A amplifier as a space heater instead!!
Old 1st February 2013, 08:12 PM   #75
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
In 45 years of being in electronics I have never used a class a amplifier.
It has always been class ab or d.
I have used them mostly for band and disco work.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 1st February 2013, 08:54 PM   #76
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
I think Joe Rasmussen was not referring to the Power and Driver transistors but "everything else" .... literally.
Including "all other" transistors in your "Class AB" power amps, all in preamps, in radios , TVs, inside Op Amps, the works.
Old 1st February 2013, 09:12 PM   #77
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Automobile have also low efficiency.... internal combustion
engines are 10 percent efficient...the rest is heat.
They must ban automobiles first.
regards,
Carlos
Old 1st February 2013, 10:06 PM   #78
Boscoe is offline Boscoe  United Kingdom
Hopefully they are banned as they a waste if time! But no the police will not be knocking on doors investigating class A amplifier usage. It will however most probably be banned for commercial products. In the UK standby has to be less than half a watt and will have to go not standby after 30mins or so if the unit is not being used.
Audio projects and more: gswdh.co.uk
Old 1st February 2013, 10:07 PM   #79
regards,
Carlos
We can't help that and I don't thing the majority care about class a amps but they do about their cars!
Old 1st February 2013, 10:13 PM   #80
My TV goes into standby after 3 hours automatically.
Class A electronics ban?? fact or fictionHide this!Advertise here!
Sure-Electronics.com class d amps kellyinvestor Class D 396 5th December 2011 05:20 AM
Burning/running in, fact or fiction? nad Solid State 47 17th January 2010 09:31 PM
Extemis - Fact of Fiction sbolin Multi-Way 15 23rd January 2005 03:29 PM
Found on Ebay - fact or fiction? Nuuk Multi-Way 53 24th April 2004 06:10 PM
