Class A electronics ban?? fact or fiction - Page 5 - diyAudio
Old 25th February 2010, 07:01 PM   #41
The one and only
Nelson Pass's Avatar
There's 33.6 kilowatt hours in a gallon of gas. I justify my
class A consumption by skipping my drive to the post office
once a month.
Old 25th February 2010, 07:31 PM   #42
Several of the CFLs I have purchased recently 'turn on' at an intensity only a quarter or less of their rated value and take several minutes to reach full brightness. Needless to say, this is not satisfactory operation.
Old 25th February 2010, 07:48 PM   #43
Account Disabled
once a month.
Hey there Nelson !
Just wanted to say hello - we've never met, but I owned a Stasis 2 for more than twelve years - so in a way.....we have met.....Thanks for everything you do!!!
CJ
Old 25th February 2010, 08:12 PM   #44
T11 is offline T11  Slovenia
Default oh,
We are really starting with with the technology as we defragment digital to reach recognizeable analogue state with it... As a light designer, artist (digital and analogue-oil and stuff ), and fellow music lover and DIYer I found some relation between hi-fi and light source industry. While I wanted to leave A class amplifiers because I wanted something more efficent and running cooler in summer I searched for the amp to satisfied my needs in music (and went through kits of switch amps, AB class amps, chip amps etc...). And I always missed something I had with my old A class amp (same speaker, same source...). In between I stared to learn more and more about the light design and started to work for a company. I after a year there I wanted to make a to us known as a "blind" test for amps, speakers etc.., but in this case would be more of a "semi blind" test as just the light source were covered. It was my beautiful new kitchen that it was our playgrounnd for a test. We tested some dozen light sources (CFL, T5, T8, LED reflectors and LED bulbs, incanescent-ordinary bulb, halogen bulbs (12V and 220V), halogen spots, metalhalogen 20W, circular fluorescent, CFL reflectors and CFL in all kind of forms). Light source was covered with a screen and nobody could see it. I must say I was dissapointed as I relly WISHED that (as in amp story) a energy efficient source win...but...the winner was ordinary 100W bulb. The closest was a halogen IRC QR111 reflector... I tried to find reasons for this and while like in audio industry you can make a decent a class amp with very good sound and musical "spirit" in it with very few parts (specially a valve amp) and make it somewhat very analogue sounding, same goes IMHO with incandescent bulbs. They are glowing wire, they are closest to sun with their nature. The rendering factor the industry hangs on for claiming good "spirited" CFLs and LEDs is just a fluke. It is like measurements we make while building and testing amps. It tells just a part of the story. To an analogue source, like glowing wire which is fire itself a Light Emitting Diode is just a small brother which is trying to reach the same status. colour rendering index is a part measurement. It is measuremet taken in some parts of the spectrum, but just halogen and incendescent bulbs are full, uncut in that spectrum other sources have high peaks and big deeps. It is like distortion measurement of and low and high NFB amp or a smooth speaker driver compared to and...let say a Lowther driver. But unfortunately colorations or better to say a miss of it is not welcomed in lighting a painting or your in-the-daylight-beautiful-home. Sun brings the truth back so as live unamplified concerts do. I could go on and on, Ok I did, but, oh you know what I wanted to say, right?...
regards T.
Old 25th February 2010, 08:33 PM   #45
Most CFLs are OK on startup when new. The difference between good ones and bad ones becomes noticeable after a few months of regular use. I've found a brand that performs well in this respect:
Ecobulb | Lessening climate change through economical energy savings!
I went through several different brands before settling on these. Some of the others started to go dim on startup after only a couple of months, or failed outright within 6 months. I've been using these for albout 2 years now and the earliest ones are only now starting to be dim on startup.
Old 25th February 2010, 09:50 PM   #46
I think LED lights are potentially a good idea if and when they ever get the cost reasonable, but the two I bought as test lights (for low stress, very low duty cycle closet lighting) failed in fairly short order (within a couple of years), both because of random solder joint failures which caused all the seriesed LEDs to stop lighting in classic 'christmas tree light' fashion.
Old 2nd April 2010, 04:32 PM   #47
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I think that it was a big mistake of the entire world not to support socialism in Western Block so it could stay being isolated there. People who lived there most probably had Karma to live in Socialist society. Now, when Iron Curtain is broken, and no more USSR and Eastern Block exist, Karma follows former habitats of Socialist countries, wherever they live now. California accepted a lot of engineers and scientists from Russia and other ex-socialist countries, so more and more laws and regulations in California resemble USSR laws. Wait until private business will be outlawed because capitalists exploit labor without direct control of society, and can break the law potentially in order to get profit.
Speaking of efficiency of consumer electronics, I have some radiators at home to heat rooms during cold winter nights. They have some electronic thermostats inside. That devices consume more energy than class A amps, but SPL is very low. That's why I prefer them, because they are quiet, unlike central natural gas heater! That means, ratio between energy consumption and output SPL is much higher than in any functioning class A audio amplifiers... May I still use them?!
Also, I have a combined device: radio, alarm clock, calculator, night lamp. Why I can't use a combined room heater & an amp?! Why the heck some collectivity is going to decide may I use combined audio & heating device, or not?! Is Socialism officially declared in our countries, or not yet?!
The Devil is not so terrible as his math model is!
Old 2nd April 2010, 06:27 PM   #48
wahab is offline wahab  Algeria
From former USSR to unemployements rate in California ,then
to Capitalism and last ,but not least ,Class A amps , to end with
Socialism as a curse...
Who said that politics is irrelevant to electronic engineering ?..
I guess that i understand why the US industry is in decline..
Old 2nd April 2010, 06:46 PM   #49
event horizon's Avatar
Actually electric bar heaters ought to be banned Semiconductor heating is vastly more efficient as there is no other output than infra red heat (from the heatsinks), unlike an electric bar heater that actually puts out some light
"Never let your morals prevent you from doing what is right!" Salvor Hardin
Old 2nd April 2010, 07:25 PM   #50
Wavebourn's Avatar
Originally Posted by event horizon View Post
Musical fires anyone?, the chairs are occupied Attachment 165290
Here you go:
YouTube - Plasma Speaker / Singing Arc - Early Modulated Prototype
http://www.youtube.com/watch?v=fRqj3...eature=related
Sure-Electronics.com class d amps kellyinvestor Class D 396 5th December 2011 05:20 AM
Burning/running in, fact or fiction? nad Solid State 47 17th January 2010 09:31 PM
Extemis - Fact of Fiction sbolin Multi-Way 15 23rd January 2005 03:29 PM
Found on Ebay - fact or fiction? Nuuk Multi-Way 53 24th April 2004 06:10 PM
Copyright 1999-2017 diyAudio
