Hey Guys,
I haven't been here in a while, but figured I'd post and ask around. I bought an Art SLA2 amp to power a pair of tweets in an active config. I popped the hood on it, and found one transistor per side and a large circumference toroid in the center. The latter being large in circ. since the amp is extremely low profile. This said, is it detrimental to have only one transistor per side? In the past, all of the amps I've purchased had at least a few per channel (4 or more). Thanks! |
#2 |
Search for Gainclone.
Candidates for the Darwin Award should not read this author. |
#3 |
Ahh yes, good point. Does this look familiar to anyone? I know it's a terrible picture, and the chip appears nondescript, but it's the best I could do in tight quarters..
#4 |
Audio Junkie
that's the power supply rectifier
#5 |
Wow, and all this time I thought designers heat sink the transistors. Further images...
#6 |
I see four outputs per channel, each with a 0R22 emitter resistor.
#7 |
Thanks djk. So, how does the build look to you guys? I mean, for a $289 amp?
#8 |
made in china?
#9 | |
It looks cheaply made but then it was cheap (although my understanding of what else you might buy for the money in the US is very limited). That may well make it reasonable value
Alan Hope is not a reliable design discipline |
#10 |
Taiwan, though obviously part of China, a friend of mine says the quality out of Taiwan is supposed to be higher than in mainland China. There's a historical reference that was made during his explanation. Either way, my Parasound A23 is made in Taiwan as well. So far, so good.
| I found this one in the WEB...i think it is very interesting | destroyer X | Solid State | 14 | 19th November 2006 04:06 PM |
| Interesting valves found | jonnypotter | Swap Meet | 1 | 6th September 2004 10:17 AM |
| Found a interesting auction.... | Andypairo | Swap Meet | 0 | 29th January 2004 08:25 PM |
| found an interesting read | kaukasion | Solid State | 0 | 30th October 2003 11:57 PM |
