GND/Earth Wiring Management by Power Amplifiers - what is the royal Way
Old 23rd February 2010, 09:52 PM   #1
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Default GND/Earth Wiring Management by Power Amplifiers - what is the royal Way
There are follow GND connections by discrete power amplifiers:
A: clean GND
1) enclosure/cabinet if it consists of metal
2) input resistor
3) RC highpass network of NFB loop
4) reference resistor of current source (LTP)
5) load resistor of predriver stage (second voltage amp)
B) dirty GND
1) Boucherot resp. Zobel network
2) load (loudspeaker)
3) neg. pole of power supply capacitor from pos. rail
4) pos. pole of power supply capacitor from neg. rail
5) center tap of transformer's secundary winding
6) main earth
If there are dual mono devices (i. e. separate and independend power supplies for both channels) the royal way for wiring is clearly to determine.
But what about normal power supply design's - i. e. one power supply and one cabinet for both channels?
In such cases I discover often very strange things like caps or resistors between the dirty and clean GND. Sometimes I observe serial resistors to some blocker capacitors.
The English brand "Moth" (Stan Curtis design), led the GND poles of the power supply capacitors about long separate cables to the neg. speaker terminals. Therefore the sound character was completly different to other models which uses exact the same power amp circuit topology.
Everyone of the individual commercial manufacturers (and diy'ers) here seems to prefer a different wiring.
Therefore the question for the royal way - thank you for your comments.
Old 23rd February 2010, 10:29 PM   #2
fotios is offline fotios  Greece
fotios's Avatar
Everything you refer it is related with the effort of rejection of buzz, hum etc noise. If you could have a faraday case to include the amplifier modules, a seperate case to include the power x-former and a perfect power supply without ripple, then you would not need any of that.
Fotios
Best Regards FOTIS ANAGNOSTOU
Old 22nd June 2012, 11:12 AM   #3
are there AES papers in this matter?
Several URLs I have found in this matter by the term "safety earth" - go to post #28 about
http://www.diyaudio.com/forums/solid...ml#post3068444
Old 29th July 2012, 05:44 PM   #4
This URLs offer a great amount of imformations:
1) Circuit design (digital, analogue, switch-mode, communications), and choosing components
2) Cables and connectors
3) Filters and transient suppressors
4) Shielding
5) PCB layout (including transmission lines)
6) ESD, electromechanical devices, and power factor correction
Design Techniques for EMC Part 1
Design Techniques for EMC Part 2
Design Techniques for EMC: cables and connectors
Design Techniques for EMC. Part 3
EMC Compliance Club – Design Techniques for EMC. Part 3 Filtering and Suppressing Transients
Design Techniques for EMC Part 4
Design Techniques for EMC - part 4
Design Techniques for EMC & Signal Integrity Part 5
PCB DESIGN TECHNIQUES FOR LOWEST-COST EMC COMPLIANCE
Design Techniques for EMC Part 6
Design for EMC Part 6: ESD, dips and dropouts, etc.
More URLs:
Banana Skins
EMC Testing Part 3 Fast Transient Burst, Surge, Electrostatic Discharge
Old 29th July 2012, 05:58 PM   #5
MagicBox is offline MagicBox  Netherlands
Good post Although I would label the GNDs differently though, as it's not necessarily dirty ground.
I'd call it "Signal Ground" and "Power Ground". After all, the amp output /speaker has to connect to a clean star point of this power ground, as does the Zobel. The capacitor leads themselves I would consider dirty. Due to the star topology however doesn't/shouldn't affect other returns, especially not the signal ground returns.
Negative Feedback: The Need for Speed
Old 29th July 2012, 06:43 PM   #6
Walkalone is offline Walkalone  Viet Nam
Excuse me, i have few question.
In the input stage, the clean GND (signal GND) is connected with RC filter input, input resistor, caps or resistors in the feedback line. But resistor of CCS and diode zener or resistor of cascode circuit must be connect in where to right way? Signal GND or Power GND?
Old 30th July 2012, 08:01 AM   #7
They lead to their respective power supplies. If you use two supplies (one for the input/driver, one for the output) it goes to the Driver GND, if you use one supply they go to the Power GND.
No matter the GND group, each group has its own local star, all the stars come together in the main star between / after the buffer elcos. Though the Power GND leads that do not come directly from the board (speaker GND) go directly to the star at the buffer elcos.
Old 30th July 2012, 09:26 AM   #8
Thanks to MagicBox!!!
I see in some schematic the resistor of CCS connect to Signal GND, not connect to Power GND, i.e Holton AV400, AV800... What's right?
I know all GND group, it's connect at the star ground. But i want to know the right way to get lowest the noise.
Old 30th July 2012, 11:26 AM   #9
It's your choice basically, if you want to star it with the signal ground, you want the cascode reference node current not to be dirty, it generally wouldn't be enough to worry about I think. For that reason, the actual Power GND may be better since the cascode's job is to relieve another transistor from voltage variations on its drain, and a minor absolute variation on its gate/base does not affect the current going through it. Personally I would pick the respective power GNDs for the cascodes, but try to route them to the signal GND and power GND meet-up on the board. If you use a GND separating resistor (10Ohm) as a meet-up, then I'd connect the cascodes to the Signal GND
Old 30th July 2012, 03:11 PM   #10
indianajo is offline indianajo  United States
indianajo's Avatar
With no lawyers involved in the design of my 1960's power amps, I don't main earth the power amp at all. Only the 1998 design CS800s has a 3 pin power cord. The hub of my system is the preamp or mixer, where the turntable headshell (green wire) is grounded. There is a wire going from that point to the 3rd pin of the wall plug, which is separate since neither the PAS2 or the RA88a have a 3 pin power cord. Installing that wire minimizes my hum, and provides a fig leaf of safety since the RCA cables do the grounding of the power amp. With 1960's RCA cables there is probably enough copper in the wrap conductor to take a significant fault current, but I can't say anything for cost reduced 2000 cables.
Interesting, these power amps do not have the dual transistor input structure of every modern amp design (or op amps) and don't seem to need it IMHO.
The other details of internal star design are interesting. thanks for the review.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
GND/Earth Wiring Management by Power Amplifiers - what is the royal WayHide this!Advertise here!
Thule Audio's GND Management by Integrated Amplifier with RC - who can explain tiefbassuebertr Solid State 4 8th January 2018 08:10 PM
Power Amplifier - Pre Amplifier Unity gain - Voltage gain - where as royal way ? tiefbassuebertr Solid State 9 9th June 2011 06:49 AM
Tannoy Royal Monitors. whitelabrat Multi-Way 17 22nd January 2010 06:22 PM
Wiring Amplifiers PSU Stinger Chip Amps 34 19th April 2009 06:48 PM
Tone arm earth wiring and DIN plug questions. tubenut Analogue Source 8 14th August 2005 05:51 PM
