#21 |
I replaced 12 electrolytics today, Hammond 1968 parts labeled "AO-xxxxx" and they didn't cut costs, mostly Mallory and Sprague parts with 66 or 67 production dates. After charging with a multimeter ohms scale, 4 were leaking pretty badly, dropping 10 mv or more per second on 2 volt chargeup. 8 were probably "Okay". Two of the leaky ones were tanalum 10uf caps with 77 date code. I could have put the "Okay" ones back, but I replaced them, mostly with plastic film 20 uf caps that will never need replacing. Three caps had 77 production dates on them, so a factory tech had been in this chassis to make repairs once before. Do what you want, if I go to the trouble to remove one end to measure a cap, I'm spending the dollar to replace it with something new and long life or reliable by design. Half the electrolytics in the organ were replaced with film caps if they would fit, or ceramic if they wouldn't. The 10000 hour caps I did buy look like the caps in the long life AB motor drives, with visible seals around the wires coming out the bottom.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300 Last edited by indianajo; 25th February 2010 at 02:50 AM. Reason: More data |
#22 | |
You sound like an experienced technician... I'm a bit curious about what kind of "motor drives" you're referring to(industrial)? What have you experienced with large (>5,000uf) can caps in power amps? I have a few amps over 15 years old that still have original PS caps, which is why I'm looking at replacements. Thanks. -Chas Last edited by clm811; 25th February 2010 at 08:34 PM. |
#23 | |
I tend to agree with Sakis in post #17. |
#24 |
Many electrolytics use some form of elastomer (rubber) as a water seal. Rubber deteriorates simply due to age and atmosphere. The US government is now issuing a warning about tires over 7 years old. If a 15 year old or older cap hasn't leaked yet, it might if stressed. There are some nice pictures of electrolytic explosions on the Hammond thread of organforum.com. When an electrolytic explodes on your pcb or chassis, it takes a lot of cleaning to get back to "insulation". Admittedly these are on tube circuits, which can pump a lot of energy into the cap and boil water when it shorts. My advice on historic preservation:Save the can and the sleeve, put new smaller guts in it, make it look good.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300 |
#25 |
Lower voltage caps will also ooze some very nasty materials. There is the bad caps issue also:
Badcaps.net - Badcaps Home Capacitor plague - Wikipedia, the free encyclopedia |
| paralleling film caps with electrolytic caps | jarthel | Power Supplies | 386 | 23rd April 2013 09:09 PM |
| tube rectifier life expectancy | Raj1 | Tubes / Valves | 12 | 20th June 2004 05:40 PM |
| Opinion upon amp life expectancy at 5 hours/day? (theres a catch) | Layberinthius | Tubes / Valves | 20 | 17th January 2004 05:02 PM |
| More Electrolytic Caps | MRehorst | Swap Meet | 3 | 26th December 2002 10:56 PM |
| Electrolytic Caps | MRehorst | Swap Meet | 5 | 12th December 2002 03:45 PM |
