Ok I'm getting parts together to build this amp but there is one thing I'm not sure about. D5 and D6 say LM336 which seems to come in two flavors, 2.5 and 5 volts. So which one is correct?
#2 |
It doesn't look like a real Borbely, op amp should be jfet, and would have 2sk216 and 2 sj79 drivers after the VAS, changed input and VAS devices and several other changes. It looks like cross between one of his line amps and one of his power amps................................... Erno now uses blue LED for cascode voltage reference for jfet/jfet cascode - Erno's power amp VAS use jfet/mosfet cascode with higher cascode reference voltage because of using the mosfet for higher power / voltage handling-
the jfet /jfet cascode should be ok for 24 volt rails Last edited by ticknpop; 22nd February 2010 at 03:09 AM. |
#3 |
I'm not really familiar with this VAS, but it seems to me 2.5V allow larger voltage swing and 5V are maybe a little bit more linear. I would try 2.5V first.
Have fun, Hannes |
#4 |
The principle is described here:
http://www.essex.ac.uk/csee/research...%20cascode.pdf Due to the low voltage of 25 volts and not having a separate PSU for the pre-stages, 2,5 volts seem to be the right choice. 5 volts will result in lower output voltage, as h_a states.
Best regards Bo |
#5 |
Thanks everyone. Guess the title should have said "based on Borbely". I just ordered parts last night and only gave it a thought afterward. Of course I picked the 5v version but oh well. Here is a link to where the boards came from.
DC All FET Cascode class A amplifier PCB Borbely ! - eBay (item 220494425166 end time Mar-11-10 23:46:13 PST) |
#6 |
somehow I have doubts that they asked Papa Borbely for permission - to make pcbs for his design
my Papa is smarter than your Nelson ! tnx to |
| FS-Borbely Class A mosfet | nicoch58 | Swap Meet | 8 | 29th September 2009 09:45 AM |
| Little Class D question | The Dragon | Class D | 4 | 16th May 2007 09:01 PM |
| Another question about class A. | boxedin | Solid State | 72 | 10th January 2006 11:58 PM |
| Question on PS for class AB vs class A | Duck-Twacy | Solid State | 7 | 10th June 2004 10:44 PM |
| Borbely DC-50 Class-A 20watts | PassFan | Solid State | 5 | 6th January 2002 11:59 PM |
| Page generated in 0.10119 seconds (74.35% PHP - 25.65% MySQL) with 11 queries |
