Ola Amigos:
Got a bad LA3170 in an otherwise nice Yamaha tuner. Thinking (hoping) I can replace it and it's partner straight-up with a burr-brown type op-amp on a brown-dog adapter but can't find a real datasheet for the LA3170 in order to confirm. Can anybody confirm anything about an LA3170 for me? Is it a simple/straight SIL op-amp with 'normal' pinout so I can drop in another general purpose audio op-amp? TIA... |
#2 |
Attached is a datasheet for the LA3170. It's in Japanese, but you can still read most of the specs and pinout.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#3 |
Might want to compare it with some of JRC's SIP opamps
#4 |
The original is made by Sanyo, and of course discontinued. The pinout doesn't seem to match JRC's sip modules so you will be stuck making an adapter board. What part of the circuit are they in?
#5 | |
Dang, seems pretty clear I can't drop in something. I confirmed from my schem that the pinouts seem to be: 1 - V+ 2 - N/C 3 - Inverting Input 4 - Non-inverting Input 5 - V- 6 - compensation? 7 - Output 8 - compensation? Which is totally different than the JRC's... The Brown Dog adapters are geared towards the JRC modules so if I used those I'd have to cut traces and re-work - not difficult but not as easy as plug & play. Seems like my choice is either that or go with NOS LA3170's, which I can dig up and obviously would work to get back operating but wouldn't be the upgrade that a modern op-amp conversion would be... Partial schem snapshot: ![]() Full gutshot: Opamp locations: |
| Should I get Subs or regular woofers? | DeadSpeaker | Car Audio | 25 | 8th August 2009 08:29 PM |
| F&T Dual Section Box Quantity Special Offer | MCampbell | Vendor's Bazaar | 0 | 2nd June 2009 06:10 PM |
| FS: horn subs, drivers, 'regular' subwoofer drivers | John Sheerin | Swap Meet | 0 | 1st August 2004 11:33 PM |
| vifa 8" on special | steverb | Multi-Way | 0 | 20th May 2003 08:11 AM |
| Page generated in 0.08486 seconds (72.55% PHP - 27.45% MySQL) with 11 queries |
