Old 21st February 2010, 06:00 PM   #1
drspiff is offline drspiff  United States
Default Multiple Receiver Switch Box
{if this is in the wrong forum, please move it to a more appropriate place}
I'm in the process of building a switch box which will allow me to switch multiple receivers. The basic idea is similar to a speaker switch, but instead of one output to many inputs, it is many outputs to one input. For instance, on the shelf is a Sansui G8000, a Scott 390R, a Fisher 400, and a Yamaha CR-1020. I want to be able to audition the same speakers with multiple receivers.
This first pass uses some 4PDT relays to do the switching. But a comment on another thread about using MOSFETs to replace an output relay started me thinking about a solid-state switch box. My limited understanding of MOSFETS suggest they would be the perfect solution. High off impedance, low on resistance, and low switching voltage.
Any ideas, comments, or guffaws will be cheerfully accepted.
Dr. Spiff
RCA multiple input rotary switch, where? gychang Parts 2 6th July 2009 01:14 AM
Alternatives to squeeze box for multiple room setup ceebmoj Digital Source 0 28th February 2008 01:09 PM
switch between two amp-inputs, multiple channels gazzary Everything Else 3 3rd October 2007 01:38 PM
How to switch single pair speakers across multiple amps? ransom peek Multi-Way 0 21st February 2005 03:30 PM
Effect of multiple drivers on ideal box volume hellomynameiswill Multi-Way 6 1st August 2001 02:26 PM
Page generated in 0.06768 seconds (65.86% PHP - 34.14% MySQL) with 10 queries
