Anybody familiar with current limiting on Technics amp modules?
Old 20th February 2010, 04:50 AM   #1
Conrad Hoffman is offline Conrad Hoffman  United States
Default Anybody familiar with current limiting on Technics amp modules?
Trying to fix an AV amp, SU-G86, probably from the '90s. It prematurely current limits at a couple watts into 8 ohms. It should do over 100 watts. Can't find any shorts, nothing burned or odd looking, all the caps measure ok for C and D, all the resistors, diodes and transistors also measure ok. The amp modules have a line labeled Overload, shared between two modules. I assume either can declare an overload situation, pull the line and trip the relay. The relay gets tripped sooner with a load, but even without a load it trips at about 20Vpp out. Does anybody have experience with Technics power modules (RSN3305-P), or access to data sheets?
Thanks,
Conrad
I may be barking up the wrong tree, but at least I'm barking!
Old 20th February 2010, 11:42 AM   #2
east electronics is offline east electronics  Greece
east electronics's Avatar
i will presume that ofset readings are correct and also elctrolytics arround the protection circuit are replaced ....
it is obvious that a bit of ofset will alert the protection circuit
As we speak i will try to dig a schematic
regards sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 20th February 2010, 11:46 AM   #3
ok i have the schematic ....please e mail me so i can give it to you its kinda big to post here
Old 20th February 2010, 04:24 PM   #4
Thanks Sakis, email sent. I'm hoping this is some simple leakage problem, but I'm not going to change all the caps without more of a clue as to what area might be the trouble. All the caps have been measured in-circuit and they show correct value and low D. That doesn't mean one or more couldn't be leaky, but I want to isolate the trouble before pulling parts on a guess. My fear is that something is amiss within one of the power modules, and at $70 each the repair wouldn't be worth it.
Best,
Conrad
Old 20th February 2010, 07:52 PM   #5
I got this thing is a somewhat disassembled state. I reassembled it with all new hardware, and now it's working. I hate it when that happens. Either there's a bad solder joint, cracked trace or the screw-down connection to the board grounds wasn't good. I think I'll beat on it a while and see if any glitches show up.
CH
Anybody familiar with current limiting on Technics amp modules?Hide this!Advertise here!
Help with current limiting device Rob11966 Power Supplies 2 23rd November 2009 06:47 PM
LM338 Current Limiting imix500 Parts 48 22nd October 2009 11:21 AM
Current limiting behavior?? stoc005 Solid State 10 10th February 2009 02:53 PM
Does any power amp have a current limiting device? beppe61 Solid State 44 22nd December 2005 11:47 PM
Load Current limiting k1jroth Solid State 2 20th November 2004 06:20 AM
