Old 18th February 2010, 01:43 AM   #1
Heeler is offline Heeler  United States
Default CS800x Fan
Hello,
Ihave a cs800x. It has been in storage but recently I have had to crack it back out.
The fan is a 2 speed fan. After some use the fan stopped working. I know that the Nidec 450 is obsolete. I would like to know a good replacement for this fan that would move more air. The unit has been cleaned and works well other than the fan. Thank you.
Old 18th February 2010, 02:45 AM   #2
llwhtt is offline llwhtt  United States
Call Peavey, IF and WHEN you get through they'll have something. Prices are USUALLY pretty good too. It IS the fan that is bad right? Some of those models had a fairly large resistor in the fan circuit that runs pretty damn hot if I remember correctly, overheated/broken solder joints is the result.
Craig
Old 18th February 2010, 02:59 AM   #3
Thanks Craig,
I am sure it is the Fans. They are suppossed to run at a low speed until hot and then run at the higher level. This won't even start up when first powered on. You can hear it try to engage but it doesn't start.
Peavey does have the exact fan but was hoping for an aftermarket if possible. Peavey makes it next to impossible to order as there is no online ordering option and being on the west Coast, the Misssissippi hours are brutal.
Thank you for such a fast reply.
Old 18th February 2010, 07:47 PM   #4
You're better off using the right fan for this, otherwise you may not get the low speed to work anyway, as it's current controlled, so the speed of the fan on 'low' will depend on the windings in the fan. The wrong fan may either run too fast when cool (not so much a problem) or fail to start at all when cool.
Craig is right, theres a large 20W resistor to drop the current down in 'cool' which is shorted out when 'hot'.
Old 18th February 2010, 10:09 PM   #5
Enzo is offline Enzo  United States
PV opens at 8AM central time and is there until 5PM. That is 10AM to 7PM pacific. Seems reasonable. the time to call them is right when they open, that is when the phones are least busy there.
Have you actually extracted the fan and applied working voltage to it directly?
There is a 400 ohm 15-20 watt resistor in series with the fan, then a triac to short across that resistor when the temperature sensors tells it to. If that resistor breaks a lead, the fan won't run until the amp gets real hot.
After all, you plan to remove the fan anyway, so why not test it?
Old 24th February 2010, 12:57 AM   #6
Default Pacific and Central Time (HA, HA )
Not to nit pick but Central time is 2 hours ahead not behind. That makes it 6am to 3pm and unfortunately right in the way of my day.
Thanks to all wh helped on this. I will test the resistor. I have found a service center. Unfortunatley I live in the sticks and it is a 2 hour drive. Thanks again to everyone.
Old 24th February 2010, 01:03 AM   #7
Default Resistor is good.
Hey guys.
I did test the resitor and everything is cool ( no pun intended.)
Peavey CS800X Amp ecris Solid State 14 8th September 2010 01:45 PM
Do I want a fan? buliwyf Tubes / Valves 12 21st October 2005 10:58 PM
fan kinser Everything Else 6 27th April 2004 10:09 AM
Fan rulezzz Solid State 9 10th January 2004 06:36 PM
Page generated in 0.10116 seconds (75.09% PHP - 24.91% MySQL) with 10 queries
