Class AB Amp kit
Class AB Amp kit
Old 18th February 2010, 04:15 AM   #11
lanchile is offline lanchile  United States
lanchile's Avatar
Originally Posted by Bigun View Post
Nice amp lanchile - looks like you have a BIG torroid in that box
Thanks Bigun, The transformer is 670vac 35 X 2 from Toroid corporation of Maryland (www toroid.com). the caps that I am using are Mundorf Audio Grade caps 40,000uf 63v.
Old 18th February 2010, 06:35 AM   #12
Bengali is offline Bengali  United States
very nice lanchile! hmm, worth looking into further. the key is fatiguing you mentioned is not there with this amp.
I have a Pioneer AVR with the ICE amps, don't care for the sound these digital amps produce.
Old 18th February 2010, 07:15 AM   #13
lanchile's Avatar
Yeah,That is the key!!! I can listen to it all day and still want some more.
I had so many good commercial amps including Bryston B60 and Bryston 4B But this amp kicked their butts big time! I am not joking.
Old 18th February 2010, 03:52 PM   #14
if you don't mind me asking, what speakers are you using with your nvx200?
thx
Old 18th February 2010, 04:02 PM   #15
lanchile's Avatar
thx
Right now I am using Polk Audio RTi A1.
Old 23rd February 2010, 11:44 PM   #16
is your psu standard CRC? you got me going on these aussie amps now.
are they self biasing or you need to tweek a trimmer?
thanks
Old 24th February 2010, 12:16 AM   #17
Spartacus is offline Spartacus  United Kingdom
This is a superb amp that uses an interesting topology
GB150
It's big selling point is its exceptional PSRR meaning that the quality of the supply impacts the sound much less than usual.
Old 25th February 2010, 12:07 AM   #18
GB150
have you built one? do you know what FET's it uses?
curious what it can output into 4ohms.
Old 25th February 2010, 12:14 AM   #19
I've built a couple. The use IRFP540/9240 mosfets doubled up (i.e. 4 total) at the output, all other transistors are BC550/560 series. Power is rated at 150W into 8 ohms, not sure about 4 ohms, but feel free to send Greg an email.
Old 25th February 2010, 03:06 AM   #20
lanchile's Avatar
thanks
Well, as you saw my amp, it is a simple power supply using some smooth caps on bottom of each mur860 (bridge rectifier board from Audiosector). These amp kits are tested and biased by Anthony before they leave.You do not need to adjust nothing just plug and play!!!. I will post some pictures of these high quality boards.
Class AB Amp kitHide this!Advertise here!
mosfet class a/ab amp p robertson Solid State 30 9th February 2010 12:07 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 08:52 PM
tweaking a class AB amp blunt Solid State 49 24th March 2007 02:59 PM
help!ab class mosfet amp mbonus Solid State 31 19th September 2005 05:14 PM
Simple class B or AB amp. Mr Evil Solid State 3 21st August 2004 01:58 AM
