Old 11th February 2010, 07:49 PM   #1
pat allen's Avatar
Default BGW 7000 rebuild...
One of theses came into my hand all apart and in severe condition...i decided to bring it up.
It is very surprinsing how small the wiring is into this amp, especialy because of its power rating.
Anyone have things to share about thoses amps ?
btw here is the end result, i changed ALL wiring in it, few outputs and predivers.
It looks ugly but plays loud and ok.
I made i play in bridged mode for 1 minute with 100v ac output undistorded on a 8 ohm load...i think it is good now
It will go well in my amp collection, next to a CAS II, a NAD something and two Proximity and a Kenwood.
Electronic engineer for automotive market.
Old 11th February 2010, 09:26 PM   #2
qsa is offline qsa  Germany
qsa's Avatar
My favorite was and is BGW 750B with dancing red LED
and previous 750A in quasicomplementary design
rebuild this amps in todays 2 HE is easy, did PCB sounds much more better compare to todays low cost PA amps
Old 11th February 2010, 09:30 PM   #3
pat allen's Avatar
yup it was easy, i had most of the parts in stock already, just the pre drivers, and i changed the semi obselete 2n3054 with TIP41c. Almost same spec. It costed me like 20$ to fix it all.
Old 12th February 2010, 01:50 PM   #4
sakis is online now sakis  Greece
sakis's Avatar
Oh god those memories ...i used to work in a club that had four of these .... we thought at the time that these amps was made from the moon or something .... almost 30 years ago
nice amp i would go for recaping the banks though also relocate them in an upright position if possible
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 18th April 2011, 09:55 PM   #5
.Sorry to steal the topic! ......Hi Guys,Newbie here.I have a BGW 7000 power amp like the one here.It has a few issues I would like to fix.Can anyone point me in the right direction to a (free hopefully!) copy of the service manual and/or schematic diagram for the unit?Its been sitting here in my room now for about 3 years untouched!Thanks in advance,Greg
Old 19th April 2011, 03:09 AM   #6
Let me know if you have any luck. I have a BGW 7000 power amp that just went out on me over the weekend! It was playing fine then all of a sudden it stopped and popped the circuit out on the back. I felt the amp and it was hot so I let it cool down and attempted to reset the switch. It made a humming noise for about 3-5 seconds then popped the circuit out on the back again. I believe the humming noise comes from the fan. I am looking for anyone that might be able to help me get this back up and running asap. I sent an email to a local repair shop and he said it sounds like it needs at least new filter capacitors and a rectifier for the power supply, and he told me it would cost $125-$150 US depending on the exact parts cost. I am sure this is an easy fix and I could do it myself because the amp doesn't really have much to it! Any help would be much appreciated.
Old 22nd April 2011, 09:12 PM   #7
masterjay,
PM sent
Greg
Old 24th April 2011, 04:53 PM   #8
djk is offline djk
djk's Avatar
Sounds like shorted outputs to me, quite expensive at a shop, DIY wouldn't be that much.
Candidates for the Darwin Award should not read this author.
Old 6th May 2011, 05:50 PM   #9
When you say outputs are you referring to the transistors?? Does anyone know where I can get replacement transistors and the correct part numbers? I have never replaced them before but I assume they can't be too hard to fix. Is it as simple as taking them out and putting a new one in? They look like they have some sort of adhesive on them. Any help would be greatly appreciated.
Old BGW 550D sfox50 Solid State 2 17th December 2009 01:20 PM
BGW 500D Bias Adjust ??? Loud & Clear Solid State 36 11th September 2009 08:57 PM
BGW Pro 250E on the blink DanGriffing Solid State 1 23rd September 2008 06:59 PM
BGW performance series help mechaboy1 Solid State 4 1st October 2006 04:17 AM
BGW 750 transistors chrisbeech2 Solid State 1 16th January 2004 11:50 AM
Page generated in 0.12877 seconds (71.71% PHP - 28.29% MySQL) with 11 queries
