Camtec Marriola MIG D1 does not power up
Old 11th February 2010, 12:25 PM   #1
reflexsa is offline reflexsa  South Africa
Angry Camtec Marriola MIG D1 does not power up
Hi all,
A friend gave me his car amp to try and repair. This is what it states on the aluminium housing:
Camtec Marriola MIG D1, 1 channel 3200watts max digital amplifier.
When power is applied nothing happens at all. There is no power light, overload light and as far as I can tell there is no rail voltages or any potential on the power supply capacitors.
I have opened it up and nothing looks obviously broken.
I can measure 12VDC on the center leg of the power supply FETs, I think that's the drain.
However when looking at the pulse with modulation IC, which is a TL494, I cannot measure 12V on pin 12 and there seems to be no voltage what so ever on any of the pins.
I measured continuity of the ground to the ground battery terminal and there is a connection there.
I am not sure where the 12V for the PWM IC is supplied from and I am struggling to follow the tracks etc without a schematic.
If anyone has any advice I would greatly appreciate it.
Thanks in advance.
Camtec Marriola MIG D1 does not power upHide this!Advertise here!
DC power house needs PS for D1 and F1 khundude Pass Labs 2 19th November 2008 07:13 AM
FS TDA1545A DAC with async reclocker, PASS D1 and battery power Andypairo Swap Meet 3 4th June 2007 07:52 AM
D1 with Loveltech EUVL Pass Labs 1 12th October 2006 10:00 AM
D1 I/V links dsavitsk Pass Labs 2 22nd November 2005 06:03 PM
D1 I/V questions was ist los? Pass Labs 12 21st November 2003 03:17 PM
Copyright ©1999-2017 diyAudio
