Hello !!
Sorry if you think this question is stupid, but i'm a complete newbie to this. I want to build a PSU for my amp that I build. I got this transformers already: 2 x transformer (primary=220V, secondary=2x18V) I want to feed my amp with +- 45-50V. How do i do ??, Please help !! |
#2 |
try this, it will give you +/- 50V
#3 |
Your schema looks okey, but i cant find the zero(0) on each transformer?
#4 |
Sorry, now I seen it.
If I understand this right, then I should not use the 0 from the transformers!? |
#5 |
Hi.
Iceman...I'm little bit confused here.If I understood you well,you have a transformer with two separate secondary coils.If it is,wire them like shown bellow.But here is a suggestion.Order a transformer with 72V on secondary.Of course with a center tap.This will give you 2x50VDC.Make your life easy! By the way(just in case)tell me the core ratings of your transformers.If you are not sure, write down the transformer dimensions. Regards. |
#6 |
HighTec
This is how my transformers look: |
#7 |
Hi.
Aha...ok!Use the S1 / S2 and leave center tap unwired.This will give you 36V. You didn't mention transformers core ratings? Regards. |
#8 |
HighTec
If you connect it like the b) example and then rectifie it which voltages will you get? and will you get a GND |
#9 |
Hi.
That's why I suggested Iceman to order a new transformer. There is no way to get +/- 50VDC from a transformer he has. I'm also sceptic about his transformer ratings! About fig.(b) he will get 50VDC but without the common ground. Cheers. |
#10 |
So you will get +/- Xv with example b. Can i use the ACground to ground it or can i make it in another way if i dont have a ground on the ac outlet
| 0-30v 0-10a PowerSupply | gev | Power Supplies | 16 | 24th May 2006 08:06 PM |
| PC PowerSupply | gev | Power Supplies | 0 | 24th July 2005 01:00 PM |
| DC powersupply +-15V 2-3A | JensRasmussen | Solid State | 9 | 22nd February 2004 09:42 PM |
| Powersupply | Kongen | Solid State | 4 | 26th October 2003 03:19 PM |
| Page generated in 0.12745 seconds (68.88% PHP - 31.12% MySQL) with 11 queries |
