Ultimate ECC for Class B from Thule Audio? Topology also used by Teac
Old 7th February 2010, 05:28 PM   #1
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Default Ultimate ECC for Class B from Thule Audio? Topology also used by Teac
Are this an ultimate approach for an error correction topology for Class B and getting sound like pure Class A at the same time?
This topology from Anders Thule also inside by some amplifiers from Teac (go to the first PDF attachement) as I note today.
In my old folder from Thule Audio there is to read follow:
One topic of key interest is to reduce the switching distortion and output impedance without compromising the time response performance at a complex load. The switching distortion appears when the power output transistors are switching and sounds particular hard and unmusical.
For this reason Thule Audio has developed a special error correction circuit, which convert the power output transistors to an near perfect buffer, to eliminate nearly all switching distortion. The remaining distortion is a more "musical" type.
The damping factor is increased (= low output impedance) to about 80 for unbalanced and about 150 for balanced products and is identical for low and high frequencies, which are very good values.
Therefore the Spirit amplifiers have:
None global feedback for good stability
Reasonable low distortion (THD < 0.08%, 20-20k Hz).
High damping factor, for both high and low frequencies, for good drive capability
This combination has the wanted dynamic, open and detailed sound, which on the other hand never becomes hard.
Because I discover this topology also by Teac - thus Anders Thule also developed for Teac
A power amp schematic sample of TEAC A-BX10 you will find in the first PDF attachement and some other images of the devices in follow attachements.
The complete schematic of TEAC A-BX10 you can download there:
ftp://ftp.vegalab.ru/%D1%C5%D0%C2%C8...C0%CB%DB/TEAC/
The whole circuit topology is close to his own IA-50/IA100 amplifiers
Are this error correction topology really developed from Anders Thule?
Except by Thule and Teac devices I haven't see this topology.
Who knows more?
Old 12th February 2010, 01:37 AM   #2
About
http://www.diyaudio.com/forums/solid...ule-audio.html
you will find many pictures from a visit in the factory of Thule Audio, that I have found on a Danish website.
Old 14th July 2010, 11:50 AM   #3
no informations?
Old 18th July 2010, 11:08 PM   #4
Default TEAC A-BX-10 inside, PCB, top view
TEAC ABX-10 inside, PCB, top view
Old 19th July 2010, 05:38 PM   #5
Default Teac Made in Denmark by Anders Thule
Anders Thule from Thule Audio not only developed for Teac. He even produced for Teac at least the model "ABX-10" from previous post and the A-BX7R (ABX-7R, see pdf attachement)
The A-BX10 ii seems to be close by Thule's model IA-100 (the predecessor of the IA-100 from the "Spirit"-line); and the ABX7R? this I don't know (perhaps the unbalanced and unbridged version of IA-50). Thus I can also offer service for this models and all the other Teac's stereo devices, where Thule Audio components are inside.
File Type: jpg Thule Teac A-BX7R owner's and package.jpg (40.7 KB, 73 views)
File Type: pdf Thule Teac A-BX7R open + front (IA50).pdf (126.4 KB, 222 views)
Old 20th July 2010, 05:27 PM   #6
djk is offline djk
djk's Avatar
What am I missing here?
It just looks like ramming some one-sided current into the pre-driver to create some DC off-set (to be corrected by the front-end). I guess this would insure that one half of the output stage doesn't turn off.
Candidates for the Darwin Award should not read this author.
Old 21st July 2010, 06:18 AM   #7
Nrik is offline Nrik  Denmark
I also see only a triple emitter follower with a bias-adjust and CCS .
Henrik
Old 21st July 2010, 01:21 PM   #8
Default Thule calls their Error Correction "Virtual Class A"
about the Alexis Internet Archive I have found this and have create and attached PDF-Files. The last file is the schematic of Thule Audio's unbal. amp devices with follow PCB: EM1070 Rev 8. Here is to see a current mirror insted a CCM
File Type: pdf Thule Amplifier circuit design considerations.pdf (68.8 KB, 373 views)
File Type: pdf C ...-A-Thule Audio unbal EM1070-8.ckt.pdf (22.3 KB, 324 views)
Old 21st July 2010, 01:36 PM   #9
Allen Wright is offline Allen Wright  Switzerland
R.I.P.
OK, but I see 10k R's in series with this "one sided current injection", so whatever it's doing current wise, it's not doing much.
Marketing hype, IMO.
Regards, Allen
Old 21st July 2010, 06:13 PM   #10
djk is offline djk
djk's Avatar
"OK, but I see 10k R's in series with this "one sided current injection", so whatever it's doing current wise, it's not doing much."
The triple EF stage probably has a current gain of around 100,000 (20x50x100).
Ultimate ECC for Class B from Thule Audio? Topology also used by TeacHide this!Advertise here!
What happen to thule audio? Ipanema Solid State 95 3rd March 2017 05:28 PM
Thule Audio Vintage Integrated Amplifier IA-120 (IA120) Schematic wanted tiefbassuebertr Solid State 19 17th May 2016 09:10 AM
Thule Audio PR-250B Service Manual wanted Sidiropa Digital Line Level 4 3rd September 2014 06:09 PM
Class Ab Oposite Topology east electronics Solid State 4 29th December 2007 01:46 AM
Pure Class A topology Bigred Solid State 4 16th September 2007 12:31 PM
Copyright ©1999-2017 diyAudio
