Old 7th February 2010, 02:14 PM   #1
tiefbassuebertr's Avatar
Default Better Audio by Solid State Amps after Coaching of certainly Electrolytic Caps ??
I discover this website from Ukrain - the motherland from Vitali and Wladimir Klitschko:
and the translation with loss informations:
Google Nachricht
Here's called this step "Electro training" instead coaching. About this I have never heard before.
The electrolytic capacitor is DC biased, additional a ripple current burden with help an AC voltage of different frequencies.
Basicly this is a AC coupled power amplifier with a 2 ohms dummy load instead the loudspeaker.
What happens in real world ?
Old 13th February 2010, 03:33 PM   #2
Nazar_lv's Avatar
Send a message via ICQ to Nazar_lv
Ukrain
right would be "Ukraine".
it is not surprising.
Coaching electrolytic capacitor in low current devices such as DACs, phonos preams, preamps etc is not efficient, much more efficient would be training electrolitics in a such device with high current and white noise(or in range 50-30000Hz) before soldering to PCB, sonically the difference is very big between electrolityc before and after electro training.
For high current circuits such as PSU of output stage power amplifier there is no need to training electrolytics before soldering to PCB.
"In developing audio devices we can always find creative non standart solutions that will ensure the best sound" (с) www.overture.org.ua
Old 14th February 2010, 10:42 AM   #3
can one really different look the capacitors for power supply and that one for signal requirenets if there are high currents?
Have a look to schematics from post #13 about
Threshold amps DC Protected
in this case
Old 14th February 2010, 01:38 PM   #4
Nazar_lv's Avatar
tiefbassuebertr sorry i dont understand what is you question.
All signal currents flow via output capacitors from such floating PSU design and the is no need to coach them before soldering
Old 14th February 2010, 01:47 PM   #5
At first look this is for me the same than that, where all signal currents flow via the output capacitors from floating PSU design. Obviously not for you. And this is, that I don't understand.
Old 14th February 2010, 01:51 PM   #6
Nazar_lv's Avatar
For high current circuits such as PSU of output stage power amplifier there is no need to training electrolytics before soldering to PCB. training can be done when cap is soldered to PCB with white noise generator
Old 14th February 2010, 01:54 PM   #7
analog_sa's Avatar
Translated into English this is probably about break-in of electrolytic caps. You have never heard this before?
Solid State Guitar amps worthwhile?? AuroraB Instruments and Amps 113 4th June 2010 01:32 AM
Op Amps in Solid State Guitar Amps MrGuitardeath Instruments and Amps 1 11th February 2004 07:43 PM
solid state amps dj_hendo Solid State 0 26th January 2004 12:24 PM
Tube vs solid state amps chrille Tubes / Valves 5 7th August 2002 03:40 AM
Power Suplies for solid state amps promitheus Solid State 11 17th May 2001 11:08 PM
Page generated in 0.09294 seconds (75.68% PHP - 24.32% MySQL) with 10 queries
