Thank you for relying.
What I mean was "can the relay kick on if the OUTPUT TRANSISTORS WERE TAKEN OUT OF THE CIRCUIT BOARD?" Without the OUTPUT ...C: 33 Volts, Bass: 32 Volts, E: 0 Volts. When I put the OUTPUT back in the circuit board then the Bass turns to be zero Volts ???? Last edited by tommy1; Yesterday at 09:54 PM.
#2 |
It all depends on how the relay is driven. Different designs drive them in different ways. Most pro amps do a self-check before firing the relay, checking for alsorts of errors. I wouldnt power the amp up without transistors in anyway, it might cause heavy currents through other parts of the circuit, drivers etc
#3 |
Thank you Kev,
#4 |
Hi Kev,
Everything is fine , now. Except the relay, it won't kick on. I found there is ac IC C1237, and I think it is broken. |
| Need Help About Speaker Relay! | tommy1 | Solid State | 13 | 9th February 2010 06:49 AM |
| speaker protection relay trouble | lordy | Solid State | 21 | 23rd October 2004 04:08 PM |
| Speaker Line Relay | poulkirk | Everything Else | 3 | 24th September 2003 10:41 AM |
| Speaker Relay | thylantyr | Solid State | 7 | 25th April 2003 06:03 AM |
| Speaker protection relay | PH104 | Solid State | 4 | 20th February 2002 07:46 AM |
| Page generated in 0.08300 seconds (72.17% PHP - 27.83% MySQL) with 10 queries |
