strange problem with DiY amp strange problem with DiY amp - diyAudio
Old 5th February 2010, 11:30 PM   #1
bobekucor is offline bobekucor  Croatia
Default strange problem with DiY amp
Hi, 5 or 6 years ago I haver built this power amp
Motorola Hi-Fi power amplifier - circuit diagrams, schematics, electronic projects
it is built with TL071cn and 2*28V
this was my first diy amp, and hasn't been used at all since then, till today
I found it in some parts box, and decided to put it together,
amp "works" and sounds great, however, it has one strange problem, when input stage is opened, DC voltage appears on output and power darlingtons get really hot in matter of seconds (would get smoked if left more then 3-4 sec. this way)
when input is connected, there is no anny issue at all and amp works great
I wouls appreciate if someone could help me solve this
thanks,
Slobodan
Old 6th February 2010, 12:58 AM   #2
sregor is offline sregor  United States
Normally, I would guess an oscillation problem, but after looking at the circuit, I would wonder if your are removing the ground to the non inverting (pin 3) input and letting the input float? If you want to continue troubleshooting the problems, try putting resistors in the out put collectors so they don't burn up or overheat.
Steve
Old 6th February 2010, 01:32 AM   #3
a.wayne is offline a.wayne  United States
Sin Bin
Maybe here :
Before the first “turning on” you must short circuit the inputs of the amp, and put a mA-meter on the output, than turn the amplifier on, and tune the R13 pot, to decrease the DC current on the output, to some uA-s, or in a lucky situation to zero. I was able to decrease it to 10 uA.
Just a thought .......
Old 6th February 2010, 02:04 AM   #4
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Could be the floating input is picking up RF and oscilating at the output.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 6th February 2010, 02:07 AM   #5
ashok is offline ashok
ashok's Avatar
This looks more like rf oscillations. Try adding a resistor from the input to ground , as low as possible. Like say 10 K ohms. This will prevent the input from being 'open' when you remove the source . Alternatives would be to change the capacitor C1 on the nfb resistor . C2 provides feedback at HF. Wonder how it's value affects the circuit. The opamp on the circuit shows a 741 ! That's very slow compared to what you have put in. Maybe the c1, c2 cap values need to be changed.
Did you try any other type of opamp ? But it's a good idea to keep a 10 or 20 K resistor at the input to avoid an 'open' circuit situation.
AM
Old 6th February 2010, 02:31 AM   #6
whoa, I added a 10k resistor between input and gnd, no problem any more, however, it seems to me that sound has changed, hmmm, just my imagination or?
btw thats nice suggestion with caps value, I think these are already adapted to 071, can't remember really, it's been a long time since I built this
tomorrow will check this, its 4,30AM so going to catch some sleeping time
thanks guys btw
Old 6th February 2010, 02:33 AM   #7
thanks guys btw
10K might be loading your preamp a bit.
Try 22k and 47k and check for oscilation and difference in sound.
strange problem with DiY ampHide this!Advertise here!
strange amp problem!!! moonchild Solid State 23 14th January 2006 12:05 PM
strange amp problem feelander Car Audio 1 8th June 2005 07:21 PM
Strange problem with amp lumanauw Solid State 10 12th March 2004 12:59 PM
Strange little problem (or maybe not so) elizard Chip Amps 8 4th January 2004 06:25 AM
Copyright ©1999-2017 diyAudio
