I don't find a datasheet about the display driver U3090
(used e. g. by Proceed audio devices). Who knows more? Thank you for your advices. |
#2 |
TFK U3090 (U3090MK) for Marantz from Telefunken (display driver for Futuba Display FV112) Datasheet still wanted
for troubleshooting in a CD player PCD2 (PCD 2) from Proceed I need a data sheet of the 40-pin. dual inline IC "U 3090 MK" from Telefunken Mikroelectronik. The same type also used in some Marantz models from the same aera. complete own create schematics of PCD2 you will find there: Proceed PCD2 Unfortunately I am not succeed to find a PDF data sheet. |
#3 |
I have 15 pcs of U3090MG in original Telefunken tube pakage. Please do not hesitate to contact me if you need
#4 | |
I have heard, that this IC together with the same Futuba display works also in some cd player models from Marantz. If I have the exactly models, I can order service manual and then I have at least the internal IC functional circuit (block diagram). Last edited by tiefbassuebertr; 7th June 2010 at 09:11 AM. |
#5 |
in the meantime I have find out, that a wide range of German's IC's are not to find about alldatasheet and datasheetarchive and even not about
Phase-Control Circuit - General Purpose Feedback In the attachment you will find cover images of folders and databooks from Telefunken (TFK, later Temic Semiconductors), where the U3090 (U 3090M U3090M 3090) could be mentionded. Perhaps one of the members might have one of this databooks and can check out this - thank you very much therefore. BTW - about the thread was also mentioned this VFD controller in use by a Sony CD player: http://www.grix.it/forum/forum_threa...d_thread=17075 Who know the associated model number? Last edited by tiefbassuebertr; 25th December 2011 at 05:47 PM. |
#6 |
no datasheet?
BTW - the correct numbering for the PCD-2 (PCD2) is U3090MG ("U 3090 MG") as you can see in the jpg attachment |
#7 |
hi,
it is the some as tms3763 You may find it in philips cd player (cd 650/cd620/cd820/cd604 etc...) |
#8 | |
Search Results - TI.com From where you have get this information? Are there a Philips/Marantz service bulletin, where this is to read? Thank you for your advices. The block diagram of TFK's U3090MG unfortunately does not replace a detailed data sheet. About Old Philips DAC module - info. required. both chip types are mentioned (MAB8441 firmware - home-brew bit-bashing technique, go to page 6). BTW - more images from Proceed's PCD-2 I have upload there: Proceed PCD2 Last edited by tiefbassuebertr; 30th January 2012 at 07:55 PM. |
#9 |
PCD2 is basically very similar to cd650. I find as display drivers U3090 or TMS3763 in many cd player marantz (40 50 60) or philips ever with display FV112. Sometime was k.o. only U3090 but in this PCD2 i find k.o. also MAB8441 & MAB8461. By ebay i find also the correct revision upc (Mab8441xyyy and Mab8461xyyy). |
| 6N9P data sheet | vitalstates | Tubes / Valves | 4 | 8th December 2009 06:48 PM |
| 90A740 data sheet please | DAKOS | Parts | 4 | 23rd July 2009 05:11 PM |
| looking for old data sheet | unclejed613 | Parts | 3 | 13th May 2007 06:35 PM |
| Data sheet for B220SS | jez | Multi-Way | 5 | 22nd March 2005 07:56 PM |
| data sheet | KCC | Parts | 5 | 6th January 2004 09:03 PM |
| Page generated in 0.12169 seconds (78.75% PHP - 21.25% MySQL) with 11 queries |
